D9GTS will probably do 7-6-5-18 1T 2000Mhz within 2.2v which is awesome:up:
yeah that would be sweet I might get some better ram chuck it in this rig do some damage and use these sticks in my upcoming build GA-MA790FXT-UD5P + AM3 3.0 black when it comes out then I can finnaly get into some amd quad core benching once I get my single stage retuned I want to throw it on my rampage and this E8600 for some action aswell
Could someone help me, i would like to have the dimensions between holes for NB sink? Thanks !
Cheers, that block fits the standard heatpipe assembly. Looking for the dimensions of the holes in the board itself though, not 100% sure if they are the same...
I had an idea a While back to make an Evap for a small single stage unit and make it modular using the fusion block as a reference for the screw holes just mount the evap onto the heatsink assembly and freeze you your entire board just a small single stage perhaps R290 as the gas something cost effective but man you would cool everything on the board but you would have to spend some extra time insulating lol
and loco I know the OP took this whole board appart and replaced with new heatsinks so he would def know I have yet to do so I hate all in one heatpipe design everything should be dedicated thats the best thing about some of DFI's board the come with beast cooling but sometimes the NB cooler isnt even on the board and the keep it simple to upgrade where it matters
Ozzfest, nice vcore - mine will be 1.55+ with LLC for 32M at 5.1G, but still cool probably....high vid A606 was lucky for me on air. Estimating i'll need 597-600x8.5 for 9 minutes. Less with a GTR or GTS kit.
never took the RE heatpipe off since NB temps etc have always been low, but my DFI LTX48 came with a twisted NB heatsink.....and no contact with the heatpipe :down:
so hard to find here now, a shame for this board really, and my 32M....:yepp:
A big part of my voltage issue is more so heat I can tell there is too much static migration at 1.48 volts, too much voltage makes everything unstable because this chip likes to be cool my temps are 60 at idle at like 4.9 or whatever running 1M takes it to like 72 73 now this is all on water tripple rad dedicated to the cpu only using fusion and D5 with modded top temps with TRUE lapped mounted modded and push pull were even worse thats why I got H20. Funny thing is my clocks at 5.0ghz+ were because the wind was blowing toward my window in my room I cracked it open the like 4c drop in ambient helped my ocing with same voltage this chip needs to be cold.
With my single stage hooked up with same voltages I imagine I could get a better validation like 5.2 and run SPI at 5.0 plus I would get some leeway in increasing voltages.
@ cheapseats my NB Idles at like 50 C or something with the air sink and asus fan equiped im thinking of tearing down the board replacing the heatsinks most importanlty the NB temps down
some hot chip Ozz :D
i was lucky with my board cooling, NB load temps all < 40c since around october - keeping the heating off helps aswell but i had to sit in a sleeping bag for 5ghz runs :help:
Its a damn hot chip man but im ok with that because I does pretty good voltages like 4.5 is 24/7 stable at 1.29 its the motherboard im going to work on cooling better that way when I hook up my Single Stage I wont have to worry I can crank the FSB I want to do 32m at 680+ FSB validation at 700 but I think that is really pushing it with X48 I havent heard of any 700FSB validations as of yet
Actually the highest FSB validations I've ever seen for this board was 710FSB...
Right now playing with VID 1.25v E8500 Q831A666 new batch...will try any higher FSB and see...
Yeah I have to agree that X48 is **mn hot chip. With stock heatpipe + Watercool UG (EK-NB-ASUS-HP) temps I got was 55C idle @ 1.64v BIOS
Now with BP BlackFreezer my idle temps still stay below 40C even @1.72v. After finished managing to cool the mosfet down w/ second WC loop will try to get some decent FSB testing~ stay tune~
710 wow well im far behind with my highest being 620 so far but I need to cool the nb a little better and then ill get back to you
hi i have q9550,qx9770 rampage extreme and corsair dominator 1800 7 7 7 20 2n 2.00 V 2x1gb the versione is with not xmp function. with qx9770 i have the setting of rob2k( rob2k have my sistem qx9770 rampage extreme corsair 1800 2x1g 1800) this settings are stable:
Extreme Tweaker
Ai Overclock Tuner: Manual
OC From Memory Level Up: Auto
FSB Frequency: 475
CPU Ratio Setting: 8.5
CPU Configuration
C1E Support: Disabled
CPU TM Function: Enabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Enabled
Execute Disable Bit: Enabled
Core Multi-Processing: Enabled
CPU Clock Skew: Delay 300ps
NB Clock Skew: Delay 200ps
FSB Strap to North Bridge: 333
PCIE Frequency: 101
DRAM Frequency: 1901
DRAM Command Rate: 1N
DRAM Timing Control: Manual
1st Information: 7-7-7-20-6-82-12-6 (7-6-6-20 @ 472)
CAS# Latency: 7
RAS# to CAS# Delay: 7
RAS# Pre Time: 7
RAS# ACT Time: 20
RAS# To RAS# Delay: 6
REF Cycle Time: 82
WRITE Recovery Time: 12
READ to Pre Time: 6
2nd Information : 8-7-6-4-7-4-7
READ to WRITE Delay (S/D): 8
WRITE to READ Delay (S): 7
WRITE to READ Delay (D): 6
READ to READ (S): 4
READ to READ (D): 7
WRITE to WRITE (S): 4
WRITE to WRITE (D): 7
3RD Information: 23-8-1-8-8
WRITE to PRE Delay: 23
READ to PRE Delay: 8
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 8
ALL PRE to REF Delay: 8
DRAM Dynamic Write Control: Disabled
DRAM Skew Control
DRAM CMD Skew on Channel A: Delay 75ps
DRAM CLK Skew on DIMM A1: Auto
DRAM CLK Skew on DIMM A2: Auto
DRAM CTL Skew on DIMM A1: Auto
DRAM CTL Skew on DIMM A2: Auto
DRAM CMD Skew on Channel B: Delay 150ps
DRAM CLK Skew on DIMM B1: Auto
DRAM CLK Skew on DIMM B2: Auto
DRAM CTL Skew on DIMM B1: Auto
DRAM CTL Skew on DIMM B2: Auto
Ai Clock Twister: Auto
Ai Transaction Booster: Manual
Common Performance Level: 06
PULL-in off CH : All Disabled
EPU II Phase Control: Auto
CPU Voltage: 1.468
Load-Line Calibration: Disabled
CPU PLL Voltage: 1.577
FSB Termination Voltage: 1.404
CPU GTLVerf (0): +40mv
CPU GTLVerf (1): +40mv
CPU GTLVerf (2): +40mv
CPU GTLVerf (3): +40mv
NB GTLVerf: +60mV
North Bridge Voltage: 1.603
DRAM Voltage: 2.067
NB DDRVref: AUTO
DDR3 ChannelA Vref: +12.5mv
DDR3 ChannelB Vref: +12.5mv
South Bridge 1.5 Voltage: 1.577
South Bridge 1.05 Voltage: 1.100
CPU Spread Spectrum: Disabled
but with q9550 the settings are unstable. i need settings for q9550 i don't expert with overclock i've 16 years old. thanks for your help excuse me for my english i'm italian.
hey Gullo92 have you tested both of the ram slots ?.. i've found that the blue ones are wayyy more stabil than the white ones and allow me to push over 650 fsb.. you might wanna try if that helps.. also i've noticed few things that you could try to get your quad core stable.. first your ppl voltage seems pretty high, i use 1.51v or 1.53v. secondly your NB voltage seems too high for only 475fsb maybe something around 1.5v or under that would be better in getting your system stable. and finally put your DRAM Skew Control voltage/DDR3 ChannelA/B Vref on auto settings also fiddling around with the rams Performance level might help. hope this helps :up:
@ Solarfall
Hi Solarfall :) i think the settings Gullo posted yesterday are just rob2k's settings.
Rob gave them a while ago with advice but it's not clear if the advice was followed :D
@ Gullo92
Gullo, i still don't know what happened, but after your PM, i sent you some simple tests to try first for your memory stability/vDIMM, and to find vCore with different multis. Some other general tips as well but it's all i could do with no quad.... i did try :)
can you say if you have tested these, or didn't you receive my PM ?
Also, i thought 450FSB was your highest stable clock. are you ok now at 475FSB using 9770 ? i'm confused :D :yepp:
Ive Found my Gskills like the blue slots im using the 12800 1600mhz 7-7-7-18-1T currently running them at 1666 mhz at 7-7-6-16-1t but I can tell this much its hard to run these stick at latencies below 7 no matter what the speed
this setting are of eob2 he has a qx9770 rampage extreme(cordai 1800 2x1gb) my ram:
Extreme Tweaker
FSB Frequency: 475
CPU Configuration
PCIE Frequency: 101
CAS# Latency: 7
RAS# Pre Time: 7
RAS# ACT Time: 20
REF Cycle Time: 82
READ to Pre Time: 6
READ to READ (S): 4
READ to READ (D): 7
PRE to PRE Delay: 1
DRAM Skew Control
CPU Voltage: 1.468
NB GTLVerf: +60mV
DRAM Voltage: 2.067
NB DDRVref: AUTO
wth mu qx9770 thi setting are stable but with my q9550 this settings are unstable) ( i have qx9770 and q9550)
Hey is that your G-Skill is HZ series?
@Gullo92
I'm sorry that I can't help right now becuase my Q9650 just went dead. I think you should try 450 FSB and see if it's stable first, then go up for 475, use relax timing for ram like 8-8-8-24, Transection booster @ 9, and do some more testing like Intel Burn Test and see if you can get the same result in every test. It would take time but just be patient.
