These scores werent on dice, it was water...
:D
20-25c water temp.
The 300htt-comment was more general;)
Ok, i thought there was some faulty :D
were do you get this 3600+ clawhammer ? i never heard of it. can you show me one picture of the cpu please ?
hehe you are on place 5 with the 3400+ venice :D
I forgot to say where I get the 3600+ from;) The one I tried 2 days ago was from the dude who sends me all those Axxxx-chips. The other one was something I got on ebay. Unfortunately, the seller had an FX55 AAAXC as well which I wanted - but I had no chance to get it as it went for 250 bucks!:mad:
The 3600+ I tried this time is a PAAPC 0401. The other one is PAAPC 0350:D I hope I get it within a couple of weeks.
3000+ winchester in the mail last night, btw. CBBFD 0441TPMW.
I tested my second Opteron 185 LCBBE 0628 BPMW....3600 mhz with 1.472 volts only for the first tests :D should do 3.8 ghz i hope.
-22c was the best higher there will be cold bug. now i will test some more :D max temp is -35c with my single stage in windows.
I need between -22c and -18c...if the temp will be warmer the pc shut down.
http://www.abload.de/thumb/xxxyqa.jpg :( :( :(
you´re right....that is my first opteron 185 LCBBE 0628 BPMW. it dies with 1.68 volts :( you can see it in the picture....under the die there you can see a small black point...thats silicone. it smells horrible :D
-18c is to "hot" for the cpu and it freezes or shut down. i need around -22c....
now i have 3779 mhz with 1.664 volts only and there is no end....can run superpi 1m with around 3.6 ghz by the way....what a chip !
when do you get your opteron 185 models ? i need some comparison.
disable one core and you'll crack the 3.8ghz ;)
CCBBE 0613RPMW: http://valid.x86-secret.com/show_oc.php?id=365628 Opty 185 @ 3562MHz / 1.63v / 39c/45c
Best spi screen I got is attached.:)
awesome. hey I'll be joining you guys when i throw my 185 under SS. lcb9e 0742cpmw. 59°C tcase, very temp sensitive. gonna be interesting.
why can core temp not read out the tdp ? i have the same problem with the opteron 185 only.
@ biohead
LCB9E will sucks under coldness.
New Castle(?)
ADA3500DEP4AS
CAA2C 0505 FPMW
Any good? :)
I dont know...try it then you will know it :D
@ Knut
I have no water cooling so I have to do SuperPi with single stage only.
my current chip runs extremely hot. the 180 i had previously (still have it, pins missing) was also a lcb9e (vcore limited):
http://valid.x86-secret.com/cache/screenshot/205255.png
so I'll play around with this 185.
Its an Clawhammer not Newcastle because of the AS --> Clawhammer. Newcastle has AW at the end of the line.
I have here an CAA2C 0507 BPMW --> needs coldness but I have no LN2 to test it out. Cold bug is not very high around 270 mhz and -28c.
@ Knut
I tested the opteron 185 today again but couldnīt kill your score. More voltage isnīt the key :( My best result was 3788 mhz with 1.68 volts...
But prime will runs with 3200 mhz and default vcore :banana:
The temperature between the two cores is around 20c under load. :eek: -8c to -28c :D
You killed him ?
