http://www.newegg.com/Product/Produc...2E16820144102R I think it's CH-6 or maby BH-5???? ( might buy it)
What's with the new Mushkin Xtreme Performance DDR sticks? I'm guessing those are TCCDs? Redline 3200 has been removed on their site... weird. Go check their site out =)
whats the max voltage for Corsair XMS PC3200XL Pro Rev. 1.2??
Now they are running on 2.8 @ 230FSB 2-3-3-5-1T.
I just got a responce on the corsair IC thread about my mem. just wanted to let everyone know. The Ramguy lists my mem mods as TCCD :) talk about a great RMA lol I rmaed hynix and got back tccd :)
Corsair PC4000 memory.
CMX512-4000PT
XMS4000v3.4
0526123-1
He posted a ton of corsair mem listings. if anyone is interested.
http://www.houseofhelp.com/v2/showth...695#post205695
Originally Posted by BB mods's
BH-5 Sure :)
max = unlimited :D...(j/k) . It can eat 3.2-3.3v with very good active cooling :)... Push it higher because of TCCD...Quote:
Originally Posted by qujck
Anyone knows how well this: DDR DRAM PC3200 / 512MB PC3200 DDR, CL2 (GeIL Ultra, GL5123200UP), performs? And is it wise 2 use it with Dothan @ P4C800E-Deluxe?
please update the mushkin redline - they use utt ch5 and not bh5 as you mention :toast:
Originally Posted by cupra
plzz more detail :D . Thx...
Putting more than 3.1v into tccd is asking for trouble.Quote:
Originally Posted by Zanr Zij
Originally Posted by jumanji969
more info plzz ! I don't thinks so... May be it's right with G.Skill but not with Corsair TCCD hehe... esp C2PT and XLPT...
i doesn't matter whether its gskill or corsair but rather what week are used tccd's.
i remember there were some weeks that liked 3.0-3.1v but anything over that isn't advisable, especially for longterm usage.
week : almost are 443. 2 pair of XL are 503. My C2PT v4.1 IC are 449... How long about "longterm" ? I used in 4-5 month :) and no prob...Anyway maybe my rams are special because of full mod Ram HS ( copper + High performance Thermal Paste + Active Cooling ) :D. With stock HS, put it 3.1v max ;)
you've run them @3.3v for 4-5 months? wow...
i think weeks 43x were the ones which liked more voltage, i'm not sure though. newer ones like less.
437 and 440 not like more than 3.1. My 449 like max 3.3v :D... Daily 3.2v :)
okay, 449's you say.
and what about newer ones, 5xx?
I have not mod HS so I'll try :D
Hey guys ! Are all Kingston HyperX PC3200 ( not K2 , A2 ... ) BH5 chip ? I found 2x512Mbs HyperX PC3200 and wanna make sure before buying them
Yes they are... it has been answered before. But yes thank god they are, I have got a Kit they perform wonderfullyQuote:
Originally Posted by xs64
hey guys i just got corsair twinx1024-3200c2 5.2
on the list it doesnt mention 5.2, does anyone know what chips these use.
http://www.xtremesystems.org/forums/...ad.php?t=72542
promos most likely.
try testing them a bit, if they max out around 220-230 thats it.
Help us to insert it then! Post the CPU-Z "SPD" screenshot and test them a bit with different timings and report your results! :DQuote:
Originally Posted by calcal
Punisher!, you can add Corsair XMS3200C2PT rev 1.3 to 1.7 Winbond UTT.
Rev. 1.3 to 1.7? You mean 1.3, 1.4, 1.5, 1.6 & 1.7 or 1.3 & 1.7, because for example 1.5 have Winbond New BH5 (UTT BH5)?Quote:
Originally Posted by Micutzu
Do you have some screenshots?
actually xms c2 v1.4 has been reported using mosel vitelic multiple times by ramguy @corsair support forums.
That's why I always ask for screenshots ;).Quote:
Originally Posted by high5
I was refering to all of the revisions from 1.3 to 1.7, and i said that are UTT, that means either BH UTT or CH UTT (i don't have detailed info on exactly wich revision uses BH and wich CH). This screenshot is taken with a pair of v1.4 sticks at 3.4V; i've also popped the hs' off them and they were Winbonds allright.
http://img368.imageshack.us/img368/9134/340v0qr.th.jpg
I've personally seen only v1.4, v1.5 and v1.7, and they were all Winbond chips; the rest is based on 2nd hand info. Also, it seems all the 3200C2PT 1.X and 2.X are Winbond, 3.X is Infineon, 4.X is Samsung and 5.1 & 6.1 is MosEl; Corsair is using different numbers for every chip manufacturer.
Yeah, this is mostly true. Anyway in the screenshots there isn't the "SPD" window.Quote:
Does this look like ch5? I think they have changed the chips?Quote:
Originally Posted by Punisher!
http://www.xtremesystems.org/forums/...id=36252&stc=1
very nice. :)Quote:
just to make sure, those v1.4's of yours are xms 3200c2?
yes, it would be logical thal all c2 v1.x's are winbond based, however, all (i think) c2 v1.4 inquiries have been linked to mosel vitelic by ramguy. maybe you should post your info there and see whats the official response, just out of curiosity.
http://www.mushkin.com/doc/products/...ail.asp?ID=239
Anyone know anything about this memory? It appears that Mushkin has just released it. I curious as what chips this memory would have. I might also mention that I also purchased 2x1GB set of it.
kronos :D :woot:
Directely from Mushkin!!!Quote:
Originally Posted by kronos
--> 2GB XP3200 3-3-3-8 Dual Kit (2x1GB) 250mhz 3-4-4-8 (infineon)
1GB XP3200 Dual Pack 2-2-2 (2x512MB) tccd/tcc5
1GB XP4400 Dual Pack 2.5-4-4 (2x512MB) tccd
1GB REDLINE 3200/3500/4000 (2x512mb) UTT/ch
The memory I'm asking about is XP4000 with timings of 3,4,3,8 at 500Mhz. :fact:
highlander :nono: :D
here are my results..you guys will be shockedQuote:
you are correct they are ProMoss -5 IC's according to ramguy @ corsair forums
very nice :up:
i have to admit i never seen promos based ram going so high... pi 32m stable?
btw, do you have digital camera?
Same Infineon overclocked.Quote:
If you could add even the "SPD" CPU-Z windows it would be better.Quote:
I have a digital camera, and ill test 32m later when i get back from schoolQuote:
ill do it after i come back from schoolQuote:
Can anyone confirm this isn't Winbond ch5 like it should be? :confused:Quote:
Originally Posted by Comp-Freak
can't tell from a side shotQuote:
also, a note about ddr1 >pc3200 crucial ram..
on the end of the part number, there is a period, then a few letters and numbers.
example:
BL6464Z402.16TG
CT12864Z40B.M16FD or .16TD2
the first number (16) is the number of chips on the pcb. most often, 4 and 8 are single sided while 16 is always double.
the letter after the first number, T or F. T stands for TSOP, F stands for FBGA
the next letter, there's 3 options, it denotes the chip die revision, C, D and G, for 5b C, 5b D and 5b G
the last number, if there, i haven't quite figured out yet. i'm guessing a different pcb revision or something.
that out of the way, i have also discovered that 512mb ballistix can come in 5b D, single sided:
http://www.hardforum.com/showthread.php?t=946804
It do not really look like Winbonds, i think it's something other!
Here are Kingstons with Winbond BH5 :
http://img.techpowerup.org/050829/kingstonbh5.jpg
guys i just ordered the patriot 1gig kit the 3200xblk. anyone order these latley? im praying to god they still ship with the tccd and bp pcb like the used too.... so if anyone nas ordered these recently or know someone who has can you tell me if they still have the tccd chips? i realy should cancel my order and order something i know has tccd and the bp pcb... i just have a bad feeling that these xbl's arent sporting tccd anymore....
thx perc,
According to Duonger (Mushkin employee), they're not Infineon chips. See the 2x1GB thread for the post.Quote:
Ok here are my results!
Hey high5 what do u want me to take a picture of ? my ram?
Today i have 1 kitQuote:
Originally Posted by Truckchase!
i post results!
Infineon or Micron now?
And what did he tell they are?Quote:
yeah, just like the ones comp-freak & gravedigga posted recently.Quote:
btw comp-freak, that ram of yours is certainly not winbond based.
Thnx GravediggA and high5. I knew winbond has the 2 metal "lines" on de side. I'm curious what chips they have, but I think I'm going to get some other ram and sell these.
punisher is that the screen you wanted to see?Quote:
here are the picturesQuote:
Hi,I did a sandra lite test on my system and after 89 pages, one of the tips was i should be using eec/parity or registered/buffered for large memory,i have 2x512 of buffalo pc 3200u 2.5-3-3-8.16x(32mx8) winbond w83627(t) hf isa(4Q1999)
bank 0: 256mb ddr-sdram 2.5-3-2-7 2cmd
same for all four banks but only using two.
can anyone tell me why it is telling me this as i car'nt get any answers out of it?
Does anyone know what chips does it uses ?
Ultra Extreme memory
I`ve heard that is bh-5 :rolleyes: ..... If somebody knows please post .
The old Ultras used BH5, but the new ones..hmm.. don't think so! Timings 2.0-3-2-x .. that could be alot of ICs! Maybe it's UTT CH5.
It is quite strange that i only see those on Tigerdirect ..... even if it is UTT the price is not bad .Quote:
Originally Posted by GravediggA
How Do I Remove These Heatsinks???????
like all the other normal heatsinks.... pop the clips off, then EXTREMELY GENTLY, pull the spreaders off.Quote:
how do i take the clips off?
use some creativity... ;) little bit of thinking goes a long way.Quote:
PC4000 REDLINE XP4000 DDR500 (2-2-2-5-1T @~3,3V) --chip--> Winbond New BH-5 ~ Brainpower PCB ... thats wrong ... they are utt ch-5 !!
Someone Tell Me How To Take These Heatsinks Off Or Link The Instructions
They Dont Pop Off
My pqi TURBO DDR550 is using Hynix D5 + Brainpower 815 and it has a pmi sticker on it.
http://www.geocities.com/a_andlcs/MEM/pqi_DDR550_01.JPG
http://www.geocities.com/a_andlcs/MEM/pqi_DDR550_02.JPG
