What are those hair's around the smd stephen :p:
.8FA ;)Quote:
Originally Posted by ozzimark
@ Waus: I like to clean my stix of ram by rubbing them on the carpet :D actually, it's just from the paper towel I was using to clean the IC's off :P
ah, odd. really old school micron if it's the revA chips :p:
edit: brainfart. sorry. of course it's revA if it's fatties. :slap:
my 2x1gb pc6400 ballistix set:
http://www.eclipseoc.com/image/am2/DSC_0424.jpg
looks like D9GMH to me
well, i think the -25F rating is given by crucial, but technically there should be -2E chips, the ddr2-1000 @ cas5 binned chips :DQuote:
Originally Posted by Sentential
the same as on my sticks ... but i think they are realy good ;)
i agree. sadly i appear to be limited to 520mhz with this sempron's memory controller. got an intel board on the way :DQuote:
Originally Posted by Kabauterman
Great list man!
Has anyone found out what chips are used on these?Quote:
OCZ DDR2 PC2-6400 Platinum Enhanced Latency XTC 2.1V 800@4-5-4-15 chips???
You just need a better cpu ;) Like the rest of us, you've hit the max FSB of your Yonah, you got to have some luck with those...Quote:
I'm still testing, but the previous owner got my Yonah up to 261FSB, so I'll see what I can get out of my Fatties :) I'll first have to vmod my Aopen though.
The supertalent 6400 and 8000 2x1 gb kits are still based on BT-3 ics or they moved to different ones?
The Super Talents use D9GKX / MT47H64M8B6-25E.
First post updated again..:D
Pls point me where i have made any mistakes to correct it..:D
I think the B6-25F are D9GMH ??? but on my Ballistix 2x1024 are D9GMH i think its the same as B6-25F ?Quote:
BALLISTIX DDR2 512/1024/2X512/2X1024 - 6400 800@4-4-4-12 2.2V Micron BT-37E--->Micron B6-37E Some 2 x 1024 uses Micron B6-25F Some 2 x 512 uses Micron D9GMH HS=YELLOW
D9GMH is originally B6-3, afaik (micron's fbga decoder broke :(), and crucial rebinned it to -25F speedsQuote:
mhhh i think it must be soQuote:
http://img170.imageshack.us/img170/5537/d95mr.th.jpg
Ok. So among the latest micron ics d9gkx & d9gmh seem to be the best. The question is can they do 3,2,2 and which of those two is better? I think i saw 360 mhz out of the 6400 teamgroup kit which is based (for sure) on the d9gmhQuote:
Originally Posted by sierra_bound
Most 2X1GB kits will not run 3-2-2 at high speeds. The tightest you can expect with 2X1GB is 3-3-2 at semi-high speeds or 3-3-3 at higher speeds. If you want 3-2-2 timings, try to find used modules with Micron Fat Body chips. They are mostly 2X512 kits.
These are the overclocks of D9GMH and D9GKX I found on the web:
D9GMH
Team Xtreem PC5300 TXDD1024M667HC3DC OC: 363.9MHz @ 3-3-3-4, autoV, Intel 975X Link: http://www.xtremesystems.org/forums/...d.php?t=101692
Team Xtreem PC5300 TXDD1024M667HC3DC OC: +500MHz @ 4-?-?-?, autoV, Intel 975X Link: http://www.xtremesystems.org/forums/...d.php?t=101692
Corsair PC8500 XMS2 TWINX 8500 OC: 601.9MHz @ 4-4-3-5 2T, ?V, AM2 Asus M2N32-SLI Deluxe Link: http://www.xtremesystems.org/forums/...d.php?t=101837
Crucial PC6400 Ballistix OC: 418.5MHz @ 3-3-3-12, 2.5V, i975Xa Link: http://www.xtremesystems.org/forums/...t=94017&page=7
D9GKX
Buffalo PC8000 FireStix OC: 462.5MHz @ 3-4-4-10, 2.0V, NF4 SLI Intel Ed Link: http://www.pcstats.com/articleview.c...id=1954&page=2
Buffalo PC8000 FireStix OC: 510.0MHz @ 5-5-5-10, 2.0V, NF4 SLI Intel Ed Link: http://www.pcstats.com/articleview.c...id=1954&page=2
Super-Talent PC6400 Over-clocked T800UX2GC4 OC: 470.9MHz @ 4-4-3-8, 1.8V, Intel 975XBX Link: http://www.legitreviews.com/article/332/7/
Super-Talent PC6400 Over-clocked T800UX2GC4 OC: 500.7MHz @ 4-4-3-8, 2.1V, Intel 975XBX Link: http://www.legitreviews.com/article/332/7/
Super-Talent PC6400 Over-clocked T800UX2GC4 OC: 524.8MHz @ 4-4-3-8, 2.3V, Intel 955X Link: http://www.legitreviews.com/article/332/7/
Super-Talent PC6400 Over-clocked T800UX2GC4 OC: 555.0MHz @ 5-5-5-?, 2.3V, Intel 955X Link: http://www.legitreviews.com/article/332/7/
Super-Talent PC6400 Over-clocked T800UX2GC4 OC: 482.0MHz @ 4-3-4-8, 2.1V, nForce4 SLI Intel Edition Link: http://www.pcstats.com/articleview.cfm?articleID=1925
Super-Talent PC6400 Over-clocked T800UX2GC4 OC: 510.0MHz @ 5-5-5-12, 2.1V, nForce4 SLI Intel Edition Link: http://www.pcstats.com/articleview.cfm?articleID=1925
? OC: 450.6MHz @ 3-4-3-9, 2.5V, p5wd2 Link: http://www.xtremesystems.org/forums/...=102527&page=2
? OC: 512.0MHz @ 5-5-5-12, 2.3V, p5wd2 Link: http://www.xtremesystems.org/forums/...=102527&page=2
OCZ PC8000 EL Platinum Extreme XTC OC: 380.5MHz @ 3-3-3-9, 2.2V, Intel 955X Link: http://www.hexus.net/content/item.php?item=5266&page=5
OCZ PC8000 EL Platinum Extreme XTC OC: 513.0MHz @ 4-4-4-12, 2.2V, Intel 955X Link: http://www.hexus.net/content/item.php?item=5266&page=5
OCZ PC8000 EL Platinum Extreme XTC OC: 525.0MHz @ 5-5-5-15, 2.2V, Intel 955X Link: http://www.hexus.net/content/item.php?item=5266&page=5
So no really tight timings, the tightest is 3-3-3-4. If you should find a review or something with tighter timings, let me know too please ;)
how about these?
http://img526.imageshack.us/img526/8...g1171ku.th.jpg
it looks like kinda small to be the 'fatbody' chips, and yet they're rectangular shaped instead of square. couldn't really see the chip numbers, but probably D9DPN or something...
BP-3
http://www.micron.com/products/partd...=MT47H32M8BP-3
who knows how they clock. i don't think it's all that great, but it's probably not too terrible :p:
Nope...I think they're these ;)Quote:
http://www.micron.com/products/partd...6HTF6464AY-667
not too good eh? :confused:
There's only one way to find out if they're any good. Test them. ;)
those are the sticks, i was taking about the ICs ;)Quote:
Originally Posted by s7e9h3n
edit: there's a lot of winking going on :lol2:
AHH...I C..hahahaha:para:Quote:
http://eclipseoc.com/image/Isee.jpgQuote:
ok. i'll stop spamming now :p:
I've bought a Pair, I wonder what they can do...(god 72 hours is a hell of a long ass wait)Quote:
