Works... and works perfectly well are two different things...
Read:
http://www.osnews.com/story/22683/In...from_Compiler_
and,
http://arstechnica.com/hardware/revi...o-review.ars/6
The same code on the same processor with a differnt vendor id, ran 10% less efficiently :D
What any compiler ideally should do especially when it comes to instruction sets is check for support... otherwise, what is the point of having a standard, if no one is to follow it. What you're talking about is code optimization...
I'm sorry about the earlier remark , this one specifically... but you do see pun was intended... nothing personal. Then again, i meant to imply that if Intel knew they did no wrong, why'd they agree to such terms with AMD?
Apparently a lot of people who make benchmarking tools, whom we rely upon :P
