hey, glad some one is testing on this mobo :up:
what bios are you using?
howz the OC going? good job so far. looking to get a 1055t at 4ghz, i have a xigamatek s-1283
I have that same heatsink - the HDT-S1283 - and it seems to cope okay. I'm having temp issues (60c prime loads) in a 20c ambient room at 3.8ghz and 1.38v.
* CPU Model: AMD Phenom II X6 1090T
* CPU Stepping:
* CPU Frequency: 3900 MHz
* CPU vCore: 1.49375V
* CPU Multiplier: 19.5x
* CPU Turbo: Disabled
* CPU NB Speed: 3000 MHz
* HT Ref Speed: 200 MHz
* RAM Speed: DDR3-1600
* RAM Timings: 9-9-9-24-1T
* RAM Configuration: 2 x 2GB
* RAM vDIMM: 1.50V
* Motherboard: ASUS M4A785TD-V EVO
* Chipset/Socket: 785GX + SB710, AM3
* Cooling: Cooler Master Hyper 212+
* Temps: 24c idle/54c load
* Operating System: Windows 7
* 32/64-Bit: 64
* Stable/Suicide/Untested: Stable
^ I'll need some kind of image or other suitable proof before marking it stable. You've been added to the list, however.
http://valid.canardpc.com/show_oc.php?id=1175312
* CPU Model: AMD Phenom II X6 1055T
* CPU Stepping: CCBBE CB 1013 CDPW (I think)
* CPU Frequency: 4004 MHz
* CPU vCore: 1.4V
* CPU Multiplier: 14x
* CPU NB Speed: 2288 MHz
* HT Ref Speed: 286 MHz
* RAM Speed: DDR3-1451
* RAM vDIMM: 1.70V
* Motherboard: MSI 890GXM-G65
* Chipset/Socket: 890GX + SB850, AM3
* Cooling: Xigmatek HDT-S1283 + Yate Loon Medium
* Temps: 33c idle/54c load
* 32/64-Bit: 64
* Stable/Suicide/Untested: Unstable/Suicide?
Are you going to add my entry as well? I would like to think that my 8 hour y-crunch session was of some use ;).
Added you both. I'm sorry about that Dennet--I had missed your post a couple of pages back but you're on the charts now.
just a quick question, has anyone here got there hands on a 95w 1055t yet?
i noticed they are listed on asus site under cpu support, maybe they are just OEM but ive seen one or 2 places listing them.
HDT55TWFK6DGR
PRAZ
Nice OC on that 6.
CPU Stepping: camera was dead did not write it down...will update when chip gets pulled out next
CPU Frequency: 4571 MHz
CPU vCore: 1.575V
CPU Multiplier: 20.5x
CPU Turbo: Disabled
CPU NB Speed: 2900 MHz
HT Ref Speed: 223 MHz
RAM Speed: DDR3-1784
RAM Timings: 7-8-7-21-1T
RAM vDIMM: 1.700V
Motherboard: ASUS Crosshair III Formula
Chipset/Socket: 790FX + SB750, AM3
Cooling: Coolermaster V10 with 4 total fans
Temps: 35C idle (cnc) 57C load
32/64-Bit: 64
Stable/Suicide/Untested: Untested
http://img.techpowerup.org/100511/15210pi4571.png
cdwall: cool, think, its 1015 batch?
CPU Stepping: CCBBE CB 1013 CPAW
CPU Frequency: 4215 MHz
CPU vCore: 1.525V
CPU Multiplier: 21x
CPU Turbo: Disabled
CPU NB Speed: 3010 MHz
RAM Timings: 7-7-7-20-1T
RAM vDIMM: 1.7V
Motherboard: ASUS Crosshair IV Formula
Chipset/Socket: 890FX + SB850, AM3
Cooling: Watercooled
Temps: 52c load
32/64-Bit: 64
12 hours prime95
http://i271.photobucket.com/albums/j...hoursprime.png
My 4ghz+ requires like 1.525 or more volts... I dont know if i want to push that high.
Charts updated. Praz, I can't mark you as stable without an 8+ hour stability test. 40 minutes of LinX is insufficient.
I find it interesting that we're all using 64-bit. I've seen not a single 32-bit submission. I like that trend. :)
No problem. Remove my entries from the charts. Thanks.
Edit: Thanks for removing my entries. This is your game and we need to play by your rules and I respect that. However, 20 passes of LinX combined with 6 instance of MemTest For Windows (500% coverage minimum), 45 loops of both FarCry2 and Warhead along with all the other benches I normally post show me more for stability then 8 hours of Prime ever will.
these chips clock differently than the old C1/2/3 chips from phenoms past. i have never had one respond this well to added voltage and they dont seem to have a wall like even the latest C3 chips did. i honestly think i could get mine to push over 4.6-4.7ghz suicide if i can get the air cool enough. my phase should push it to 5ghz easy will post those benchmarks as they come in. great scoreboards BTW very clean looking unluckily my droid hates them :ROTF:
5Ghz under single stage phase will be hard to achieve, especially with monster heat load on this 1090T @ >1.6Vcore
I didn't know you'd done all of that. I just saw a LinX shot showing 45 minutes. I'll happily accept those qualifications if you want to go back up on the chart. Please excuse me as I know I may seem the villain at times--I just want to make sure that "stable" on the chart is a reliable reference. A lot of people (not necessarily you) will claim stability if they merely manage to load Windows. It's my hope to provide a bit more statistical validity than that so that a person may look at the chart and get a real idea where their chances lie.
I'm glad you like them. I actually took the time to write some software that generates generic charts like that with this (and a few other) projects in mind. It's dynamic and auto-sizing which makes it nice. I also wrote some custom management software for the charts that generates images in batch and uploads them to the website. That's why chart updates are so responsive. I just edit values and click a button to make this thread up to date. It's much less work than maintainers in the past have had to do.
Particle, you should change the unstable list to a suicide list, youll get alot more hits also for that than the stable list............plus its more fun:)
heres mine if you change your mind
CPU Frequency: 4656 MHz
CPU vCore: 1.68V
CPU Turbo: Disabled
CPU NB Speed:
HT Ref Speed: 238 MHz
RAM vDIMM: 1.7V
Temps: 27c load
32/64-Bit: 64
http://i271.photobucket.com/albums/j...validation.png
a little OT but relating to dumo/cdawalls posts.. ive heard a lot of people talk about the heat these put out but i was always under the impression that 1.5v will put out the same watts/heat whether its 1.5v on 4 cores or 1.5v on 6 cores :shrug: ive seen chew & now dumo say things that imply otherwise and im just not sure. can someone clear this up? thanks
Well Dumo and chew have taken actual temp readings with a temp probe I believe, so I would believe those guys over the BIOS.
http://3800z24.info/Phenom/CrossHair...55t-Stable.jpg
CPU Stepping: CCBBE CB 1015DPMW
CPU Frequency: 4063 MHz
CPU vCore: 1.475V
CPU Multiplier: 13.5x CPU Turbo: Disabled
CPU NB Speed: 2400 MHz
CPU NB vCore: auto
HT Ref Speed: 300 MHz
RAM Speed: DDR3-16000
RAM Timings: 8-8-8-24-2T
RAM vDIMM: 1.65V
Motherboard: Asus Crosshair IV
Chipset/Socket: 890fX + SB850, AM3
Cooling: Water, non chilled
Temps: 22C Idle / 41C Load
32/64-Bit: 64
