just got a 3020A477 980X PAKG. DATE 07/29/10. vid is 1.2v my other 980x vid is 1.1v more to follow
UPDATE: 4435MHZ @ 1.38. will push some more now.
Mine came in the mail from Amazon and my specs are:
Pack Date: 07/28/10
Made in Costa Rica
MM# 907397
FPO/BATCH: 3020A476
Waiting on a vid card, then throwing this on a REIII board until I get my watercooling all settled with. Hopefully this is a good batch...
Yeah, I'm hoping mine is as good as yours... I want to run basically at 4.2GHz 24/7 with as minimal voltage as possible. :-)
Well I think my CPU is absolute c r a p.
I managed a 4256 Mhz (133Mhz x 32) run with Linx 20 passes, on 1.45 :eek: volts. Temps were around 50 celsius on water.
As soon as I bump it to 134 Mhz I get unstable, even with a 12 multi.
I would say the F is for fragile all right...
I can't even run at stock voltages/frequency anymore.. As soon as I do Windows 7 Ultimate locks up after about 3 mins, regardless of what I'm doing.
Dodge this batch.
I think I got a voltage hungry chip from batch 3020A477, as it wont stabilize in LinX @ 4.6ghz with HT enabled at any voltage below 1.54375v in the bios (1.541v idle in OS) for LinX. Needless to say it doesnt appear to scale voltage very well at all. I'll post the screenshot once the run is complete.
Pack Date: 07/29/2010
Made in Costa Rica
MM# 907397
FPO/ Batch #: 3020A477
Batch #3013A562 is very strong, i cant kill it so easy... VTT tested to 1,75v on air :o runs 4,4G at 1,44 Ht on 24/7 :D very hard to kill
vcore tested on air 1,8v still live =) vmem tested 2,5v not dead mem controller to
Alright, here is full out on the problem size or "all" selected. I had to bump the voltage one notch to keep it from giving a stop on error after 10 loops.
# 3020A477 | Core i7 980X [6C 12T] @ 4504.1MHz | 1.517 | EVGA Classified E762 | Water
http://img.photobucket.com/albums/v7...stable4504.jpg
i7 980x 3913A472
R3E
Hyper-X 2KC8 6GB
http://i54.tinypic.com/2i03x91.jpg
3005F758T #1
CBB approx -120C @ Dual Channel
CB approx -170C @ Dual Channel
LN2, Hexus PiFast 6.2GHz @ 1.75V @ -128C @ 6c12t
LN2, AquaMark 3 max 6.3GHz @ 1.8V @ -160C @ 6c12t
the results of a very quick test in a crowded room with people bothering me all the time
3013A739 w3680 -118cb -75cbb avoid like the plague
5.2ghz pi 1m 1.58v -80c hates cold and uncore
3020A477 i980x -140cb -120cbb mediocre at best
5.6ghz vantage cpu test 1.725v -135c
As you raise the vcore the cb gets warmer IE 1.8v -125cb
No screenshots as not worth it for me to print screen lol
both on r3e
hello
I7 980X Rectail
Msi Xpower x58
h2o laind d5 + Ek supreme
4500mhz 3dmark06 1,31vt pass cpu test
http://img832.imageshack.us/img832/9...mar06131vt.jpg
4570mhz vantage 1,36vt pass
http://img69.imageshack.us/img69/887...vantage136.jpg
soon to ln2...
Worlds first Golden "F" batch? 3005F803T
http://valid.canardpc.com/show_oc.php?id=1418660
Wasn't stable for too long, bad contact on block and reversed flow on inlet outlet.
This chip really doesn't like high clocks, but rather mid-high clocks and low voltage.
Currently at 4.2 200x21, 3400uncore and 2000mhz ram at C8-9-8, 1.318V and 1.34QPI, stable for LinX however I want, and Prime, although don't believe me if you want, I'm not going to waste time spending hours for stress testing.
Gaming + high load rendering, all stable.
http://valid.canardpc.com/show_oc.php?id=1419419
http://img641.imageshack.us/img641/6509/16780726.png
Uploaded with ImageShack.us
Seems like cpu-z glitched. 1.8V????? ON WATER???
haha, click validation link :)
BenchZowner what kind of voltage are u using for 4.4 ghz. idle voltage and load voltage? are u running vdroop off or on?
running the 1.5x uncore, Cookiesowns sure seems to put your Everst numbers super low.
my child ln2
i7 980x Bacht 3012B109 -135 BY [DRACO]
Msi xpower 1.0
pot oterrauge
http://hwbot.org/community/submissio..._980x_6529_mhz
http://img412.imageshack.us/img412/2086/1423989.png
i want to buy 980x in the next 2 days and I've been reading the thread since the first page, and i am trying to gather from you guys which batch is the most trust worthy for overclocking, looks like the 3003Bxxx is the most stable and safe ones !! .. and reading about the gulftown dying is kindda scary :confused: !!!!!!!
