Pointless after 13.1V.
http://www.xtremesystems.org/forums/...d.php?t=170217
With that 2x MCP655 Dual Top...Can I run
-360 Radiator (feser)
-240 Radiator (feser)
-140Radiator (Black Ice GTSthealth)
-CPU Block
-MOBO block
-WaterBlock for hd 5850
-Another Block for HD 5850
Bump for last post??? Cant find answers anywhere else
So you think I can run all those block and rads .
3 Radiators
-Feser 360
-Feser 240
-Black Ice 140
4 waterBlocks
-CPU HK 3.0
-Asus R3E full block
-2xEK 5850 Blocks?
This is my actual setup, I want to add Full Motherboard Block, a 140mm Rad and maybe another EK HD 5850 waterBlock (Graphic Card)
http://i48.tinypic.com/29lfpk7.jpg
Im using 2xMCP655 Swiftech Pumps on the EK dual Top.
I only have one 90' adapter on my 240 rad inlet. The others are rotary 45' and 90' degress, I'll have 4 snakes
1 like this
http://www.performance-pcs.com/catal...WTP-C39_01.jpg
and a couple like this (7-8)
http://www.performance-pcs.com/catal...CPF-CC5_01.jpg
I think I'll add the other 140 radiator along with the full mobo waterblock.
Any issues with mounting this thing vertically?
Johnny, 355's have higher head pressure than D5's. Depending on the rads, you might even be able to pull that of with a single 355.
i was about to pull the trigger on buying an EK dual d5 top until i found this: http://www.frozencpu.com/products/11...tl=g30c107s156
Looks awesome, though could this could be used as well :D?
