Originally Posted by
Manicdan
i think the definition of a true duel loop needs to be defined better
the T3 is 2 pumps sharing a res, not 2 independent loops. if you have a CPU and GPU on separate loops, using separate radiators, then switching to a T3 can give you the option to balance things out, or give more flow to certain blocks.
so for example you have a CPU, GPU and 2 radiators, and currently have CPU/Rad1 on loop A, and GPU/Rad2 on loop B, the flow of loop A may be very restricted because of the block you purchased, if you move Rad1 to loop B, the CPU block gets more flow and temps get better, with the T3, two independent loops wouldnt allow for that since your cpu would be all alone, but 2 pumps using one res would.
