Just use a special verson of Riva Tuner, thank's to it's author.
pcgameshardware got 900MHz out of the "big" cooler, which kind of dents the theory that the cheaper cooler is better. Perhaps there's just a large variability in the amount of OC headroom in these chips? Would make sense seeing as these are the first chips on the new process.
Seems to be a good mid-end card.If it helps lower 4850 price even better....
4770CF has good scaling as usual, but I'd never go cf with 512mb cards
Why won't it support 3 and 4 way crossfire? It has two bridges..
Did someone try to do more than 2-way CF anyways?
How about a HD4770+HD4850 CF? Should be possible, right?
Seems a few reviews got good idle power consumption. The majority horrible. Wonder if its just a driverfix with powerplay.
But considering that review samples aint like retail is hmm hmm. Other cooler and different phase as mentioned above.
Need retail testers :p:
If it is like in the xbitlabs one. Then I'll take one.
http://anandtech.com/video/showdoc.aspx?i=3553
http://www.bit-tech.net/hardware/gra...d-4770-512mb/1
http://www.elitebastards.com/cms/ind...=711&Itemid=27
http://www.firingsquad.com/hardware/...0_performance/
http://www.legitreviews.com/article/963/1/
http://www.pcstats.com/articleview.cfm?articleID=2392
From Expreview regarding oc limit:
If you want more, just open the Rivatuner.cfg, find “RV770 = 9440h-9443h,944Ch”, and add the ID “94B3h” after.
NCIX have better prices - http://www.ncixus.com/search/?categoryid=0&q=4770
Which reviews use retail cards?
I have never used crossfire/SLI before, will my E8500 @ 4.25GHz be fine with 4770's?
The cooler is actually the same as some 4850 have − http://www.msi.com/index.php?func=pr...7&prod_no=1688
Terrible idle consumption, GDDR5 strikes again... They should pack ATI Tray Tools with custom profiles with these cards :/
cc limit is 830/850Code:OC Limits
Site Gpu Ram Sample
Expreview 900 1100 Retail
Elitebastards 820 840 Retail
Guru3d 852 1004 Review
Xbitlabs 860 975 Review
Techpowerup 825 1105 Review
Hardware Canucks Cc Limit Retail
Pcstats Cc Limit Retail
Legit Reviews Cc Limit Review
Hardocp Cc Limit Review
Firingsquad Cc Limit Review
Toms Cc Limit Review
Neoseeker Cc Limit Review
Legion Hardware Cc Limit Review
Computerbase Cc Limit Review
I know quite a few well educated gamers that work in the "tech" field who still only buy nvidia based on misconceptions about ati drivers. These are software developers and server admins btw, and they still have no clue because they aren't what I'd consider "enthusiasts".
The points is not to say that every consumer feels one way or another but to share feedback from based on your experiences and conversations with others. The consumer bias favoring nvidia does exist whether you want to admit it or not. Have you ever heard someone who isn't an enthusiast say they only buy ati?
Can someone link me to Xfire results?
perkam
There you go :)
http://lab501.ro/placi-video/ati-radeon-hd-4770
You greedy bit-tech guys, just can't say no to Nvidia's money, can't you? :down:
GTS250 anywhere to 50%-100% faster than 9800GT according to them
http://www.bit-tech.net/hardware/gra...-4770-512mb/10
