Interesting. At least on my machine, even when I have more than 500MB of stuff open, the program will page it out enough to let the program have the full 11.5 GB for the entire run.
Win7 change in memory manager?
Anyone want to try and confirm this?
thx :)
Did you verify the 350m? Only the benchmarks and the two of the batch mode options will verify to see if the digits are correct. The "Custom Compute" option does NOT since there are no checksums for them.
Just because it finishes without warnings doesn't mean it finished without any errors.
The stress test, on the otherhand, DOES verify to see if everything is correct.
The way it works is that it cycles through all the major constants that the program can compute. For each constant, it runs two computations using different algorithms. Then it matches them to see if they are correct.
It uses two threads that run completely independently of each other. Because of "dips" in the CPU usage for each computation, one isn't quite enough to keep everything busy. But two does pretty well - at least up through 8 cores. ;)
