As far as I know there is pretty much no compatibility between 32-bit Vista drivers and 64-bit Vista, so it is pretty much the same for Windows 7 as that is build upon the foundation that Vista laid down.
Wanna get a key the easy way just go here and follow the directions. You have to have a hotmail acct to logon though. Sorry id someone has already posted this, you can delete if it's redundit. http://www.neowin.net/news/main/09/0...ows-7-beta-key
Yukontrooper,
64bit OS requires 64bit kernel mode drivers. 32bit applications on the other hand aren't a problem.
You can set the desktop background to be a slideshow. A bit of OSX is creeping through.
NVIDIA have beta drivers though update as well.
I did download the Nvidia drivers through Windows Update.
Has anybody received indexing errors from trying to install 32-bit drivers? I've had them a few times now, and I think that's where they've come from. Of course, I won't be installing 32-bit drivers anymore, but I had to ask because I want to make sure it's not my hard-drive. Error check doesn't bring up anything in HD Tune.
If using a 64bit OS you should enable memory address remapping in bios too!
Just a heads up mate!
My personal flavours are either FreeBSD, Gentoo or Debian. But I've never really taken much taste to *nix GUI and never used OSX for more than a few minutes at a time.
I wish they would combine the flexibility of *nix shells ie zsh/bash/csh and Windows UI. I would be in heaven :D Powershell is nice but it's too clumsy and over-simplified that it becomes annoying.
I just couldn't get my video drivers installed on Ubuntu. It said there were no restricted drivers available, and if I tried to manually download and install them, it would half install and prevent me ever downloading other packages. With Windows I just run the setup, restart and it works. In Win 7 the drivers are already installed.
My video card fan runs at 100% without drivers installed, that's why I wanted them :(
