Last update with regular water ;)
http://www.vmodtech.com/files/orthos-4734-1hr_894.png
5Ghz done:D. Boot from bios @ 1.45v.
It's raining 5GHz all over the place! :D
My cpu is the really funny, it runs 4.3GHz at just 1.2V which becomes 1.208V under load due to LLC and runs everything i throw at it, 1 hour Orthos small ftt's, blend, OCCT, 3d mark 06, aquamark03, superpi 32M, memtest in windows, memtest 86, all no problem.
But sometimes in explorer or just after booting into windows it happens to bsod.
Hell, it even bluescreened at windows installation! :(
I'm really puzzled about this so i set all voltages to auto and raised Vcore only 1 small step in bios and now all seems stable.
No more bsod so far. :shrug:
@ Garrett, me scared? :rofl: You must be kiddin mate, i'm only trying to find a stable 24/7 setting before i will move on to pumping some real Vcore. ;)
I could boot into windows 4.9GHz with just 1.48V and run 1M, then i tried with 1.52V and worked my way up with setFSB but superpi already failed at 4930MHz.
Perhaps my cpu isn't as good as yours.
Doesn't mean i'm giving up off course.
1M has got to be done at 5GHz. :D
Seems like u all got good Cpus. Mine really sucks. I never had luck with my cpus. Spent alrdy a lot of funds without any luck. :(
Mine is 1,275 4000mhz stable. 1,45V 4500mhz stable and got spi 1M 4900mhz 1,58V.:down::mad:
Using aircooling.
Get rid of loadline calibration, that is likely why you were unstable at idle.
Finally, let's take one last real-world look at the consequences of removing Vdroop. ASUS' implementation of this feature, labeled as Load Line Calibration and included with their latest line of motherboards, is particularly worthy of our attention for a number of reasons. The first is that setting lower voltages with this option enabled actually results in a condition in which the CPU voltage under load is higher than the idle voltage. Imagine our confusion as we desperately struggle to understand why our system is Prime95 stable for days yet continues to crash under absolutely no load. What's more, in spite of the absence of droop and for reasons unknown, enabling this feature artificially raises our CPU's minimum stable core voltage at 4.0GHz from 1.28V to about 1.33V. As a result, our system uses more power under load than is otherwise necessary. Our efforts to reduce our processor's supply voltage backfired - instead of lowering the system's total power consumption we managed to affect a 20W increase.
http://www.anandtech.com/cpuchipsets...spx?i=3184&p=6
That's on air cooling Scythe Ninja 2.
Opinions?
Time sucks for 5050mhz.:shakes: But nice clock on air!:clap:
Not bad ;)
SuperPI32M 2Thread ,1Thread & SuperPI1M @ 5GHz on Regular Water again.:D
http://www.vmodtech.com/files/32m-5000_563.png
Damn hot cpu
FPO Q820A596 VID 1.1375
My 2 quads dont run this hot
http://i237.photobucket.com/albums/f...r/8600_oc1.jpg
yah but your quad's a clean gigahertz slower.
So what then would be a acceptable 24/7 setup, if you wanted the chip to last 8 months to a year.
Vcore ?
FSBT ?
PLL ?
Temps ?
I would like to think I have a decent wc setup so I was somewhat shocked at the high temps for this clock.
I would like to run 4500 for 24/7 but our house already has a furnace:rofl:
Those of you with the Q822's, where did you get them? I have a 24/7 4508mhz Q820 on air but i'm looking for a little more.....Were never satisfied are we? lol
Just went on HWBOT to keep track of the action. Here's the latest e8600 update:
one thing you should all take into consideration is of the top 10 e8600 overclocks on hwbot, 4 were done on a tpower i45 board that costs only $145.00 including the WR. 5 were on x48 Rampage extreme ($400 board) and 1 was on a GIGABYTE GA-EP45-DQ6 ($250.00)
http://www.hwbot.org/listResults.do?...true&limit=100
HWBOT Ranking For CPU-Z - Core 2 E8600 (3.33Ghz) (limited to top 10)
1 CPU-Z - 6761 mhz - boblemagnifique (Union Francophone Hwbot) 7.1 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6761mhz [#1 Core 2 E8600 (3.33Ghz) in CPU-Z] on LN2 no image
Videocard: unknown
Memory: 2048MB DDR2
Motherboard: Tpower i45 P45
Global Rank: not in top 1000, not ranked yet, or not the best result with this hardware of this user.
Hardware Rank: 1st Core 2 E8600 (3.33Ghz) - 7.1 points
Description: First test , temp = -160° and 1.9v of vcore
Verfication: verification link
Scan date: 08-08-2008 10:52
Compare url: http://www.hwbot.org/compare.do?resultId=760597
Options: [ report][team][user][ evolution ][ log ]
2 CPU-Z - 6586 mhz - No_Name (AwardFabrik) 5.7 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6586mhz [#2 Core 2 E8600 (3.33Ghz) in CPU-Z] on LN2 [ view screenshot ]
Videocard: unknown
Memory: 2048MB DDR3 PC16000 @ 1976mhz CL9.0 8-8-21
Motherboard: Rampage II Extreme
Hardware Rank: 2nd Core 2 E8600 (3.33Ghz) - 5.7 points
Description: "Warm Up" GC2008, E8600 cooled with Otti Pott -130°C, Mushkin DDR3-2000, Mushkin 800W PSU, Asus Rampage Extreme. Please visit www.awardfabrik.de = OC-Paradise ;-) --www.awardfabrik.de/forum/showthread.php?p=190607#post190607
Scan date: 10-08-2008 11:53
Compare url: http://www.hwbot.org/compare.do?resultId=761134
3 CPU-Z - 6554.83 mhz - joe_cool (Team OCX) 5 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6555mhz [#3 Core 2 E8600 (3.33Ghz) in CPU-Z] on LN2 no image
Videocard: unknown
Motherboard: Asus Rampage Extreme
Hardware Rank: 3rd Core 2 E8600 (3.33Ghz) - 5.0 points
Description: no description
Scan date: 09-08-2008 06:45
Compare url: http://www.hwbot.org/compare.do?resultId=760702
4 CPU-Z - 6506.89 mhz - Brian y. (Team OCX) 4.3 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6507mhz [#4 Core 2 E8600 (3.33Ghz) in CPU-Z] on LN2 [ view screenshot ]
Videocard: unknown
Memory: 2048MB DDR2 PC8500 @ 650mhz CL5.0 5-5-15
Motherboard: T45 P45
Hardware Rank: 4th Core 2 E8600 (3.33Ghz) - 4.3 points
Scan date: 13-08-2008 02:12
Compare url: http://www.hwbot.org/compare.do?resultId=761966
5 CPU-Z - 6491 mhz - onepagebook (Team OCX) 19 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6491mhz [#5 Core 2 E8600 (3.33Ghz) in CPU-Z] on LN2 [ view screenshot ]
Videocard: unknown
Memory: 2048MB DDR3 PC14400 @ 779mhz
Motherboard: asus Rampage Extreme x48
Global Rank: 116th - 15.4 points
Hardware Rank: 5th Core 2 E8600 (3.33Ghz) - 3.6 points
Scan date: 06-08-2008 12:03
Compare url: http://www.hwbot.org/compare.do?resultId=760001
6 CPU-Z - 6455.14 mhz - c1rcu1tburn3r (XtremeHardware-OC-Team) 17.8 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6455mhz on LN2 no image
Videocard: unknown
Memory: 1024MB DDR2 PC8500 @ 646mhz CL5.0 5-5-15 2T
Motherboard: EP45-DQ6 p45
Global Rank: 121st - 15.0 points
Hardware Rank: 6th Core 2 E8600 (3.33Ghz) - 2.8 points
Description: E8600 Q820A435 @ 1.85v (-128°C), Gigabyte EP45-DQ6 aircooled, Crucial Ballistix PC8500, Zalman ZM1000W, S3 Virge, , www.xtremehardware.it, Thanks to Gigabyte for this sample
Scan date: 09-08-2008 04:36
Compare url: http://www.hwbot.org/compare.do?resultId=760862
7 CPU-Z - 6419 mhz - jmax_oc (JMax-Hardware) 2.7 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6419mhz on LN2 no image
Videocard: unknown
Motherboard: ASUS Rampage Extreme X48
Hardware Rank: 7th Core 2 E8600 (3.33Ghz) - 2.7 points
Scan date: 10-08-2008 05:52
Compare url: http://www.hwbot.org/compare.do?resultId=761236
8 CPU-Z - 6403.61 mhz - HIWA (no team) 2.5 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6404mhz on LN2 no image
Videocard: unknown
Motherboard: Tpower p45
Hardware Rank: 8th Core 2 E8600 (3.33Ghz) - 2.5 points
Scan date: 10-08-2008 12:47
Compare url: http://www.hwbot.org/compare.do?resultId=761023
Options: [ report][user][ evolution ][ log ]
9 CPU-Z - 6403 mhz - MAFRI (HardwareLuxx Germany) 16.6 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6403mhz on LN2 [ view screenshot ]
Videocard: unknown
Memory: 2048MB DDR3 PC14400 @ 960mhz CL8.0 8-8-28 2T
Motherboard: rampage extreme
Global Rank: 131st - 14.3 points
Hardware Rank: 9th Core 2 E8600 (3.33Ghz) - 2.3 points
Scan date: 10-08-2008 03:41
Compare url: http://www.hwbot.org/compare.do?resultId=761067
10 CPU-Z - 6371.98 mhz - Qballe (Team OCX) 16.2 points - [ inspect ]
Processor: Core 2 E8600 (3.33G... @ 6372mhz on LN2 no image
Videocard: unknown
Memory: 2048MB DDR2
Motherboard: Biostar Tpower I45 P45
Global Rank: 134th - 14.1 points
Hardware Rank: 10th Core 2 E8600 (3.33Ghz) - 2.1 points
Description: , e8600 ( Q822A435 ) , Biostar Tpower I45 , Teamgroup 9600 , Fx5600 pci , Sirtek 1.2k , Kingblock By Ybris
Scan date: 10-08-2008 12:51
Compare url: http://www.hwbot.org/compare.do?resultId=761025
If you are not on HWBOT already you should register and post your e8600 clocks. It's fun and all you need is a cpuz validation account. Takes 5 minutes and your scores last forever.
hwbot registration: http://www.hwbot.org/register.do
cpuz validation registration: http://valid.x86-secret.com/register.php
I wouldn't take them over 1.400 Volts loaded, or a distance to Tjmax of less than 20
I would'nt call anything less than 4 hrs prime95 or Orthos stable. Still yet to see this over 4.5Ghz in the thread. SuperPi runs mean Sweet F... All. Whats the point of xtremesystems if its unstable...
fast sp runs mean WR
