[QUOTE=Crazypinoy9;2638123]Ez flash keeps telling me this:
"VERSION in ROM file is older than existing board!"
Have tried 0601, 0504, 0503 and same stuff
Can you upload 704 me so that i can try it?
Of course! Here is the link: 0704
NICE!!!! 704 worked! Don't know why this bios is the only one that does but all that matters is that it does. Thanks man!!
You're probably right, I also get the feeling Patriot are giving me the run around:(
I contacted ASUS support and they said all 4 slots should be able to run the RAM @ 1600Mhz so you can all breathe a sigh of relief now knowing that the 1333Mhz "limit" was either confusion between the DDR2/DDR3 combo boards (P35 ones) or a party line spun by Patriot.
Patriot are now talking about raising NorthBridge Voltage etc. Seriously what is a safe air cooled NBridge Voltage @ 333Mhz FSB (1333Mhz RAM) and what would be the recommendation for 1600Mhz?
I'm just a bit wary of burning the thing out at stock!
John
The 704 is working fine for me!
Has anyone with a Q6600 been able to OC to 3.8 w/ BIOS 601???
will v704 work with the Q6600????
Guys your aredoing a terrfific research there!! Kudos!
Thanks for trying,I cannot wait to get back from my vacation and try the newest BIOS. Unfortunately I'm 10000 miles away from my mobo right now:-)
Also,did I mention how much I hate ASUS site.
I just went there and it shows BIOSES showing the 504 as the latest for P5E3 WI/FI and 402 as the latest for P5E3Dlx.
These guys at asus should really revamp their site, sincerely it blows considering the money they are making, and when you search for an update is like going into a random lottery...
Any RS links for the latest bioses, so I can update the first page with the links so all the guys here would be ableto quickly download?
Thanks guys!
I`m using for (mostly) BIOS downloads this forum: German forum
This board begin to be good....
well i lapped my cpu and my water block... Took about 2 hours...
My cores are still not the same - 1,2 & 4 are the same and 3 is about 5-6C lower...
Anyone else w/ the same problem.... :shrug:
Thanks & Nice Desktop Pic....
Here are my new #'s....Quote:
http://img88.imageshack.us/img88/3041/1483fw5.jpg
..come on guys..lets try better with this nice mobo..:)
Sorry for a stupid question: how could I downgrade from 0804/0704 BIOS to earlier versions? AsusUpdate under windows with "downgrade" option ON don't want to flash. AFUDos 2.11 & 2.17 hang system on "Advance check". Build-in EZ-Flash also do not want to downgrade to earlyer version :(
Asus removed the 804 and everything upto 504 from their site.. i guess we are stuck with either 804 or 704 till they come up with something new..
is anyone running Corsair 1800Mhz DDR3 with this board? i'm asking cuz i cant get the RAM to run in 7.7.7.20 with 704 and 804 was a total disaster.
right now running my QX9650 at 450x9 if i can get timing to run solid then i can relax..
We are all the victims of Asus programmers vile experiments :)
I could run my CellShock at 1800 8-7-6-21 2,00v, but its unstable in Prime. I'm wondering why I can't stable run this with promised 8-7-6-21 1,9v?? I even try NB 1,65v & Mem 2,00v - no luck, Prime tests failed
The only stable&fast configuration I discover is:
Fsb/Mult 500/7
NB 1,41v
Memory 1600 7-7-7-16-CR1 1,80v
Such a config don't want to run stable with 0804 but seems to be great with 0704!
We stuck to this 0804 and we cannot change the Vdimm at all..that makes ram unstable..
Lets hope that Asus will do it fast the good bios..
I went back to the 704 from the 804 bios because I couldn't even get to 450. I do have the 704 bios if anybody needs then.
I have bios 601...
Click Here To Download -----> BIOS 601
For those who have a similar build w/ Bios v601 -Stable
http://img526.imageshack.us/img526/8791/cpuco2.jpg
Enabling the Load-Line Calibration allowed me to lower my CPU volts while maintaining a stable OS
Went from 1.59 Stable to 1.51 Stable :up: Running 2-3C Cooler now
Still trying to reach 3.8Ghz – I think my bios is preventing me from going any higher….. Tried many different variations…. All of them failed….
Can you explain what is a useful post in your opinion?
Please show me another post with more troubleshooting info about THIS particular motherboard and I'll make efforts to be up par with it....
Also if you have a Maximus Extreme, then I don't know what you're doing complaining here...
If you have a P5E3 Deluxe, and have some specs to share you are more than welcome to share with us your experience....:welcome:
@oscar3d,
Didnt mean to offend nobody (edited..)..:cool: ..actually the last posts help indeed..;)
