cant wait :d going to OC it 2,4 ghz + ?
Excuse me for this n00b question:
If memory clock is derived from cpu clock divided by some number,
so what is northbridge clock for??
I think it's not really a NB, this is just the IMC speed. On K8 it was always 1:1 with the CPU, apparantly now it's seperate.
This seems interesting to me as on K8 the IMC was suspected to play a major role in the max CPU clockspeed. A typical good K8 had mem revision B1 or BB as you will know, which would get you higher than a good week BW.
Thanks for reply..
So, IMC speed is 'internal speed' only?
To communicate with the core perhaps?
I could get 8800GT yesterday:)
http://222.151.153.254/c-board/file/...E_GF8800GT.jpg
...yes, I can't do 2 CPU operation with long PCIe board:D
I used 169.01 driver with inf file modified...it looks a bit faster than 167.26.
I tried 2.0G, 2.2G, 2.4G...and in 2.4G case, I tried 3core(1core disabled) and
2core(2core disabled) as emulation of Toliman and Kuma:)
I also tried on P5K3-D/Kentsfield with mild memory setting...
Results...screenshots are located on my BBS:
http://www.oohashi.jp/c-board/c-boar...ne;no=5231;id=
CPU clock: 3DMark Score / CPU Score
K10(BA) 2.0G=222x9: 9482 / 2999
K10(B1) 2.0G=200x10: 9353 / 2979
K10(B1) 2.2G=220x10: 10148 / 3267
K10(B1) 2.4G=240x10: 10796 / 3560
K10(B1, 3core) 2.4G=240x10: 10420 / 2830
K10(B1, 2core) 2.4G=240x10; 9423 / 1888
Kentsfield 2.4G=267x9: 11901 / 3845
Kentsfield 3.0G=334x9: 12965 / 4792
Quick conclusion from above:
*K10(BA) looks a bit faster than K10(B1), though multiplier aren't same.
*K10 score seems about 10% lower than Kentsfield at same clock.
So, K10 needs more clock!!!
I'll try CineBench10 in next time...
...now very sleeply...it's early morning here in Japan:)
Hmm, so IF the ICM was the limiting factor when overclocking K8, now we can divide ICM speed with K10, will that mean that we can gain intel-like overclocks (+4.5GHz)? :O
Thanks Kyosen.
Too bad it lags 10% behind Kentsfield now. Maybe Phenom will close the gap to Kentsfield at least.
Communication is done through the HT bus, which has a seperate speed. The Integrated Memory Controller communicates with the memory (read / write). I invite anyone with more technical background to fill in the details. :D
An interesting theory is it not? But ofcourse there are other factors.
beardy,
How do you know the barc. proc. was in single channel mode?
smartypants,
K10 is fine, I think its you that has a problem.:D
It would be interesting to see 267*9 on the AMD system or 240*10 on the intel and then to see how that cpu bench scales ;)
ok i am gonna come out and say it...
SHUT UP
no need for petty arguments.
now mabey i dident see it but is the bored ur running a 1207+? so it can utilize HT3? just curious.
yes it would... hard one to predict *concentrating very very hard channelling my clairvoyant powers* oh my god, i got it! no the fsb wouldnt have any damn effect, when the hell has it ever??
i wasent talking the FSB, HT3 is on the die correct? and it would provide direct links to the ram and what not. instead of going through the FSB
FSB x the multplier matters. MOBO fsb? Don't mean sh*t.
Things change everyday, though. :cool:
I dont know how Ganged mode works...if it is a single read/write or two but Unganged mode is two different DCT, there part isn't shared...they both write or read...and just to add, K10 doesnt read/write anymore...it reads until the DCT buffer is out of space and bursts all the awaiting writes to avoid the constant read/write switch delay.
I'm curious about how the relative clock speed between the L3 and the cores affects the L3 cache latency. If I read this right, some combinations should give lower latency than others.
To support independent clocking and modular design, asynchronous dynamic FIFO buffers are used to communicate between different cores and the northbridge/L3 cache. These FIFOs absorb any global skew or clock rate variation, but the latency for passing through depends on the skew and frequency variance – which is why the L3 cache latency is variable.
