Regarding chip's VID:
This is what I've answered in another forum for someone who asked the same questions on VID:
VID is also one thing that we can take into account to determine the chip's overclocking-ability in the later stages. Lower VID almost always means that the overclocking room will be more. Bcos you started off with a lower Vcore at stock clock, your chip may ended up requiring much less volts to acheive the desire clock than another chip that has a higher VID than yours at the same clock. Lower volts required to obtain your desired clock speed may also mean lower temp. :)
However, keep this in mind though, although I'm stating this all based on facts and statistics but this still doesn't guarantee the OC outcome in every case, just so you know:)
Gotta say thanks for enlighten me ;)
I totally forgot about the x9 multiplier route as I was so used to x8 multiplier route with my E6700.
OK, here is another explanation I'm going to make again just so you're clear about the core temp reported from Coretemp and Speedfan4.32.
Obviously you've not being reading and following my every single post carefully throughout the 7 pages, and I understand the thread is long but the infos are all there actually.
1. Forget about Vista 32bit or 64bit vs XP OS enviroment for reading the core temp correct, let me tell you simply that the OS isn't not related to the accuracy of the core temp reporting. I think I've answered about the accuracy part to someone in one of the post reply I made from the previous pages. Tjunction - DTS = coretemp and I even had a screen per the demand asking to show the Tjunction remaining from the coretemp just to show that the core temp is actually picking up the 100c Tjunction properly.
2. Pay close attention again to all my screen captures that has Asus AI suite and Speedfan 4.32 in it and look for the time for the screen that was captured. You can see that the system temp varies throughout the day. My room temp is actually 4~5c lower than the system temp reported. Do the calculations yourself and you'll find out my approx ambient temp. It's very similar to any others who also has Asus AI suite + speedfan 4.32 in the screen shots. However everyone's room conditions are different.
And obviously again you've missed the post I've made regarding the relationship btw ambient temp and OC'ed core temps in my previous page. Go dig it up and read it again.
People please don't make me explain things again for something it's already being covered. I have every motivation to show and explain all OC related subjects as clear and legit as possible so I'd hope you call can get it in the first place so no more time will be wasted from both party.
Of course, this is also one of my primary goal after I'm fully settled on a max stable clock speed : voltage : core temp strictly below Intel thermal spec of 71c on air cooling setup.
Obviously you've not being following my posts closely enough and have missed the fact that I even made a post reply to help all others who need to get Coretemp 0.95 to work under Vista x64 OS in the previous pages.
