:welcome:
Another Belgian on the team :clap:
:welcome:
03/10/2007 09:35:22|| 3184 floating point MIPS (Whetstone) per CPU
03/10/2007 09:35:22|| 7023 integer MIPS (Dhrystone) per CPU
E6300@3.25.
:p:
Be one hell of a fsb on my Ally to best the Clover :rofl:
Hmmmm, lets try 4000 x 7.....may need more than 1.3v though :rofl:
2 x 466 :p:
Nothing much but sure makes my x2's look slow at WCG :confused:
Dual Clovertowns @ 3148MHz
5.10.13 (64-bit)
Server 2003 x64
Whetstone: 3330
Dhrystone: 9338
wow , almost 31K
and your temps :up:
31K is not typical by any means. Yesterday just happened to be a better than average day.:) Every now and then I will see 28-29K.
with 5.10.20 64 bit at 3157mhz
3023/9333
I knew those were good chips you got you bastage you!:rofl:
Q6600 @ 3.38GHz
Vista Ultimate 64
4 X 1GB Ballistic PC-8500
BOINC 5.10.20
3235 floating point MIPS (Whetstone) per CPU
9933 integer MIPS (Dhrystone) per CPU
jaco what part of belgium. im in limburg. i dont speak dutch or french.
10/4/2007 3:11:17 PM||Running CPU benchmarks
10/4/2007 3:11:17 PM||Suspending computation - running CPU benchmarks
10/4/2007 3:11:48 PM||Benchmark results:
10/4/2007 3:11:48 PM|| Number of CPUs: 2
10/4/2007 3:11:48 PM|| 2793 floating point MIPS (Whetstone) per CPU
10/4/2007 3:11:48 PM|| 5544 integer MIPS (Dhrystone) per CPU
better than 2121/4237. bumped it from 2.1.3 to 2.88
I'm from Leuven . (I speak Dutch )
im in peer
E6850 @ 3.6Ghz
4GB DDR
XP64
BOINC 5.10.20 (x64)
3379 floating point MIPS (Whetstone) per CPU
10448 integer MIPS (Dhrystone) per CPU
I see that the WCG site have the latest recommended version as 5.10.22 on its download page http://www.worldcommunitygrid.org/re...ewMember=false - but its still at 5.10.21 (Beta) on the Berkeley site.
Although I haven't seen an announcement over at WCG, from a post by one of the WCG CA's it seems its a purpose built WCG version which also automatically uninstals any UD Agent present to assist in the forthcoming migration to Boinc only, and also has its own WCG skin - whether it is any improvement from versions 5.10.20/21 I have no idea :shrug:
The 5.10.22 is the version packaged by WCG and WCG-Skinned to also make use of the extra functionality to identify the old WCG (UD) agent and optionally remove that. Each WCG project, including FA@H come with their own set of slides you can see rotating in the BOINC Simple View window.
Between 5.10.20 and 5.10.21 there are lots of bug fixes and a few more with the one WCG released, some not yet documented. As always WCG recommends their checked and endorsed version, link provided on the WCG download page.... anything else and it gives support headaches
OK, I've just loaded 5.10.22 over 5.10.20, and I see that it has its own 'WCG' skin whilst installing, and some pretty slides in simple view - but nothing else.
Benchmark seems to have gone up a tad though, on a Q6600@3GHz it was 2821/5890, now its:
05/10/2007 17:38:45||Benchmark results:
05/10/2007 17:38:45|| Number of CPUs: 4
05/10/2007 17:38:45|| 2945 floating point MIPS (Whetstone) per CPU
05/10/2007 17:38:45|| 6373 integer MIPS (Dhrystone) per CPU
Could just be explained by variations at the bench time though :shrug:
11.11.2007 11:58:00||Running CPU benchmarks
11.11.2007 11:58:00||Suspending computation - running CPU benchmarks
11.11.2007 11:58:31||Benchmark results:
11.11.2007 11:58:31|| Number of CPUs: 2
11.11.2007 11:58:31|| 3393 floating point MIPS (Whetstone) per CPU
11.11.2007 11:58:31|| 7487 integer MIPS (Dhrystone) per CPU
here is my result
