loading windows is usually harder on the system as true dual channel comes into effect not to mention the loading of drivers etc. Memtest is good to be sure your memory is stable but cpu, cache and mem controller are totally different things that come into play during the loading of an OS. You can either raise voltage like mentioned above to give the memory a bit more juice when loading the OS or back of a few mhz at the current voltage.
