HTT428MHz on NewCastle 3000+ DFI_754
http://www.hot.ee/robotron/fsb.png
What is your memory stick ?Quote:
Originally Posted by sluggard
an the CPU stepp ?
it's incredible with a newcastle :slobber:
memory is async@100MHz in bios, meaning that my random value ram stick is @224MHz :p:
dunno the stepping right now, but the CPU is from 0447. still can tell you exact stepping soon...
Corsair BH5 3500 @1,5-2-2-4 1T 3.9v on the same mobo
291MHz, but unstable :cool:
http://www.hot.ee/robotron/BH5_291.png
sandra buffered
http://www.hot.ee/robotron/bh5_bench.png
superpi 1M
http://www.hot.ee/robotron/9x283.PNG
Nice result, very good RAM! :up:
EDITED:
Link Removed. No Spamming Allowed.
Just a headup while everyone's busy with their new NF4 toys, here's an update for this veteran mb:
DFI released the latest beta bios dated Jan 28 for UT Lanparty NF3, DRAM bank interleave finally made available in BIOS.
I tried myself, unbuffered memory bandwidth and memtest speed got a nice boost now. Now memtest+ with the new bios, I got higher MB/s at 265MHz than 300MHz previously with the old bios. No stability penality observed so far.
tin tin, would you try the HTT higher than 325 for us, we found the nF3 250Gb cant hit the HTT over 325...Thanks... :DQuote:
Originally Posted by TinTin
I hit 355Quote:
Originally Posted by hkalex
It depends on CPU - I had 3 and 1st did 335, 2nd 325, 3rd 355
http://members.lycos.co.uk/yotomecze/htt%20355.JPG
True.Quote:
Originally Posted by yotomeczek
I could boot and run Prime95 perfectly stable at 420 with my old ClawHammer, a pic is somewhere in this thread.
Now with my NewCastle, booting at 320 is a no go.
It's all about the CPU. ;)
Clawhammer always does it better~ :DQuote:
ours cant hit over 325 htt, even i got the DTR :slobber:Quote:
431HTT, I remember I did a 435HTT before, but I lost the picture! :DQuote:
Did you apply suitable memory divider? HTT ratio?
There is almost no need to raise the chipset voltage too much, just +0.1V~
I have a quick question...I can't seem to find my answer here in the thread...Which SATA ports are better to use on this motherboard? 1&2 or 3&4? Right now I am using 3&4...I thought I remember reading something about an issue with 1&2 along time ago...Thanks.
I used 3-4, and disabled 1-2. I'm with you, I remebered reading something about OC issues with 1-2 but I was just looking for it and couldn't find it quickly.
I had no setup problems at all using 3-4.
The issue with the SATA Ports 1 and 2 is that by using them you limit your FSB to 240 in a 1:1 ratio. You can go higher using SATA ports 3 and 4.
Oh ok...well I guess I will keep using 3&4 then. But I thought there was an issue and I was right...Quote:
Originally Posted by zippyc
Please post a link or info for this bios. I visited dfi-street.com and nowhere to be found. I can't believe they enabled BI after all the complaining I used to do about not having it has a option in the bios. :toast:Quote:
Originally Posted by ahfung
Has anyone tried using 3 sticks of RAM with this mobo? If anyone has, what kind of experiences do you have? I bought 1 BH-5 (256 MB) stick (Kingston Value RAM) yesterday to operate with my 2 x 256 KHX-3200. All sticks are single-sided and BH-5.
Testing is still going on, but I thought I should ask here what to expect.
1T setting seems to be impossible, but I thought I should get reasonable FSB for my RAM. Those KHX-sticks had no problem in 24/7 use @ 240 x 10 with 3,15 V. Now that 240 seems to be unreachable, even with 2T-setting.
Any help and advise is appreciated, thanks :)
W3rD :toast: http://s6.invisionfree.com/undercloc...?showtopic=407Quote:
Originally Posted by RacerX
There are alot more BIOS versions then that one out there...
anyone tried .09 sempron on this board yet?
I haven't heard yet
Just speccing out DFI LANPARTY UT nF4 SLI-DR build am unsure which is best out of these :-
Concerns :-
Thermalright XP-120 Pipes will they block DDR4 Slot or if orientated other way interfere with any capacitators.
(I notice that MSI Neo2 & 4s can't use this cooler.)
Swiftech MCX6400-V - Weight 750gm (Ex Fan) puts it way over the AMD recomendation of about 460gm (Not good for LanParties :D)
3rd option may be to bottle out & go for the Swiftech MCX64
Would appreciate feedback from anybody using either of these.
Performance of both is good XP-120 ahead on Temp/Noise
PC Perspective - Comparison Swiftech MCX6400
Could anyone else find this one he's speaking of? or should I just use the tictac modded BIOS?Quote:
