well tried it and no change...
thanks anyways...
Plan to take MB & CPU to the shop tomorrow
Interesting, but how does this x21-BIOS-set works in real life?
I had a chance to try it with my X5650 B1 ES (BIOS F7x). I could set it to x21 in BIOS but it ended up as x20 in w7 anyways. I didn't have much time to play with it, because I had to borrow RAM from may main-rig. I will hopefully get some RAM soon and will try to get my good old UD7 up and running again. So I'm really interested to find out how this works actually. You got a link or more explanation on this?.
has their been a newer update yet from f7x?
Yes F7 final is out seems good so far
hello there guy's
I'm new here and my first post. So I've got an UD7 rev1.0 to, with a 930.
And I have bin some sort of ginny pig, because my Saitek cyborg keyboard
has issiues whit the new F7 bios. and for me its just horrible whit overclocking.
It can't even do the same as F6 whit more vcore on 200x20 4ghz.
So why dit they f*ck up the bios, because the main think is OCing whit this board.
Because the problem whit my bios/keyboard i have tested several F7 bios.
F7w, x, y, final and a bunch of customs. And not one of them overclocks as well as the F6 bios.
F7 bios is no good for my mobo :shakes:
Very good this F7 BIOS!! Nice visual
I like the lastest f7 bios my system runs great all the f7 beta's i had problems with keyboard unstable overclocks and ram bugs but in my mind the new f7 is the best so far maybe im just having good luck with it :D
Not really on topic here but..........I'm interested in the UD7 heatsink and was wondering if anyone is not using W/C maybe they would want to swap for a UD5 heatsink plus $$$. PM works good for anyone interested, thx.
Theres the MSI XPower, dunno if thats good enough for you but i consider it bang for bucks :cool: Or the Rampage III Extreme, though i won't really classify that as bang for bucks. EVGA classified good for OC, but lacks U3S6 and is expensive.
Otherwise, theres always the UD9 you can play with but definitely overpriced:yepp:
Hey guys,
What's the best bios for gigabye x58a-ud7 ??
After many many time...
...today i start to OC my ud7 & my i7920......
the new PWM delivers MORE power with less (different) phases ;)
