Yeah tedy those sticks are hit and miss one of my sticks did 240..with errors... :stick:
the other flew to 261 ...Lol..it only did 258..but when I did that step up test...it kept geting higher
Bwan ..nice job Btw
Bwan ..nice job Btw
VAGP helps the overclocabillity of a system - as for an Inlel one - I haven't tested it on an AMD system to see how it does.......On EVERY Intel rig out there , uping the VAGP you always gain......Vchip helps a bit though......VAGP IS feeding the Northbridge with more juice and performs a lot better at 1:1 , 5:4 and 3:2.....Uping it at 2Volts though you might "loose" a bit of VGA's Core MHz.....Quote:
Originally Posted by bwan
I also found out that uping the Vio(from the PSU 3.3V line) at about 3.65Volts , helps overclocabillity as well...... ;)
Way to go bwan...... :toast:
3.4v :banana:
http://freeweb.siol.net/akersman/265.JPG
littledevil memtest stable ? some proof ? :)
Lol..everyone is kicking some arse with these twinmos!!! :banana4:
Show us some super # !! Litledevil...and congratz :toast:
Hmmm I have my AGP voltage at 1.6 from default 1.5. I will try 1.7 and see what I come up with. I currently have my 3.3v rail at 3.42. Are you saying raising that to 3.6 or so will also help stabilize my board and allow higher overclocks? If so I will raise the pot some more.
I wish you luck cantankerous! I have an NF2 too and waiting for your result :) I will bump my OCZ rail up too Good luck.
Thanks Negative Design. To be honest I already have a max limit of 243 on my DFI LPB. I was hoping for more which is why I am going to try the above mentioned. I am going NF4 soon anyhow so I hope to get at least 260 on that setup. I just changed some cooling in my case and bought a Zalman FB123 bracket to help cool the dimms. I hope for greater results. I will surely keep you posted.
Do you have VX/UTT on your NF2? If so what are you getting from it?
Originally Posted by cantankerous
Im not doing to good on mine :( I have BH5 and I'm stuck at 240FSB I think I need more volts because I can only stabilize it by relaxing timings :(
Are your sticks getting hot? alot of ppl said their UTTs stay cool,my BH5 on the other hand is HOT! 60C lol.
My BH-5 doesn't even get warm dude. I'm doing 10x294 2-2-2-6 @ 3.5V
Do you have a screeny of that?!!!Quote:
Originally Posted by Klisp
That's amazing :toast:
they don't get warm @ 3.5v at that speed? lol gotta be kidding me! :p:
yea mine are pretty hot. The max I seen them get to is 51c at 3.3v but that was in an enclosed humid room. Normally under memtest they get to about 48c and under gaming about 41c.
screenshot please ;)Quote:
Man I can't wait till get my dam sticks..is it monday yet?
Everyone needs to post some pics if they can
Mine do :) I put a temp probe on the bastards and it gave me 53 load.Its strange but all 3 running 2gether get HOT! especially on memtest at 230FSBQuote:
But when I mix my mushkin with my ultras they do 243FSB 1T and stay warm! I guess bad combo/sticks get warmer then good ones,I just found this out last nite btw,after mixing my 5 sticks.
stable?Quote:
ive never even heard of that with 2x512.
edit - oh wait, maybe 2t will do that...
anybody knows what kind of ram is used in PCStats review? http://www.pcstats.com/articleview.cfm?articleID=1724
I saw the "dimples" in one of the shot, but not sure if they are AA4T's or not....the SpeedPremiums won't post at CL2 :(
yeah thats them... -44d with dimples :)
only fed them 2.8v hah, if only they knew.
I think they knew...but didnt say! bcuz they dont want ur hungry geeks to want them more!
Or maybe they didnt want their sponsor OCZ to get mad who knows.
ok, thanks guys. i thought they were aa4t's :(...
They are aa4t on the white stickerQuote:
ok, thanks guys. i thought they were aa4t's ...
The 44d refers to the last few numbers on the memory chips itself.
Hope I helped
*********************update*********************
Recieved 4 sticks today all aa4t...
Stuck one stick in..has been around 40 minutes..still going strong at
3.3 250 fsb...Going to jump it up and try 260..
2 2 2 2 2 11 13 15 Timings.might not be the correct ending order but you get the jist of it.
I'll be doing the 3.1 to 3.3 test as well ..I'll contribute my findings to that thread
Anyone know why I can pass memtest 260mhz 20 loops of #5 and I can't get into windows?
Give it more volts :banana:Quote:
Originally Posted by mcbarnet007
that's not the solution....it is already at 3.5v
if it pass memtest it should load windows right? considering I have 4000+ running a 9x multi.
Is memtest screwed up? or windows and memtest uses different setting?
