Originally Posted by corruption
If your cpu's default voltage is 1.4v then you WILL NOT BE ABLE TO USE ANYTHING ABOVE 1.45V FOR VID. That's why 1.55v * 10% will give you the same voltage as 1.45v * 10%. I have had no problems with any of the 1.9 beta bios's either. I'm beginning to think that in your case there is either a user "issue" or you have a flakey board. :shrug: I've added, and removed, the 4th phase to my board and have had no results worth mentioning....neither positive or negative. Are you sure that you're measuring CPU voltage from the right location? (The correct mosfet, and the correct leg on the mosfet.) Are you grounding the negative lead on the case?
I have had positive results from 4 rigs that I've built around the K8N Neo2 Platinum.....none of my builds have had any problems that you seem to be experiencing aside from innacurate readings from core center, mbm, speedfan, or any other "monitoring software." Unless you have a bad board, getting an nForce4 board will not help your overclock. If you're looking for the added features that the nForce4 chipset brought to the table, then that's a different story. I feel badly that you seem to be having so many problems with your motherboard, and I hope that they can be resolved somehow in the near future....good luck to you. ;)
