Tue but the way information flows through the GF100 is quite different from the GT200.
Also, at this point in time everything will be "evolutionary" versus "revolutionary" since the unified shader-based architecture will be with us for some time.
no. both digital VRM and traditional step-down buck converter, can output any voltage from 0 - 12V. For both digital, and analog component (ie cap, inductor, diode/MOSFET rectifier) selection determines max current, transient response (ie ripple current) etc.
Caps are high and block heatsinks. AMD digital VRM is better for heatsinks. Multiple-phase solutions are easier to link up. And can better manage switching... ie reduce voltage/clocks/current if overheating.
Its kind of like old school jumper/BIOS overlocking vs using setFSB in Windows - the later obviously easier and more convenient.
I've been wrong but I dont think so. TSMC 40nm is still far from "mainstream" and quite expensive. Only reason for AMD to drop down to $300, would be if Fermi launched at $300 - infinitesimally improbable.
Does anyone think dual GPU Fermi is possible at all (GTX470, and downed clock speeds like the 5970) without requiring a nuclear power plant and generating as much heat equivalent to the surface of the sun?
No Fermi is the first mass market GPU architecture to have:
#1: Parallel geometry setup
#2: Generalized, coherent read/write caching
Both are huge deals because of the engineering effort required and make a lot of things easier to do. Of course it doesn't mean squat if you just care about the fps that comes out the end.
My recommendation to ATI would be to adopt/adapt the CUDA api from nvidia and get on with it. Let's be honest, nvidia has the clout to raise a stink big enough for everyone to notice. Their connections run deep.
Unless ATI is planning an API release secretly. I really hope they aren't, waste of resources.
@triniboy: I'll check it out. This gives me something to research :)
I believe ATi could adapt CUDA easily, if they want to.
But i agree with you, we need a common API for assessing a GPU (just like AMD and Intel CPU that csn run a sett og common instructions and programs).
Somebody has to provide a common platform to take this further to the next step where everybody can have a personal supercomputer :D, but these guys (nVidia and ATi) are too busy fighting each other, and Intel will actually see both of the dead and defeated in this area, Because a great GPGPU platform can threaten the Intel dominance in those very suspensive supercomputer marked.
There are two other reasons to drop the price on the 5870 to $300
- If the 480GTX comes in at close to its current price/performance to deny any signficant marketshare. If the 480GTX comes in at 5-10% higher performance than the 5870 would the average upgrader still choose it if the 5870 was 25% cheaper (probably not)?
- If AMD/ATI counters with a 5875 (or whatever 5870 rev2) at the same price point of the current card (to retain "performance crown"), the "old" 5870 wouldn't sell at all at the current price.
I'm inclined to say that its very likely AMD/ATI would price cut, I'd probably bank on it being closer to $50 though (I would be quite happy if it was $100).
Ati definietely has price flexibility right now.Dont forget that ATI prices have risen above launch msrp.They are cheaper to produce, they have them for months, and have had better yields from the start (6 months ago).
Thing is, if they will not feel threaten by fermi, they probably wont :/.MSRP for 5850 on launch was 259$ ,it stands at 300+ now.
Yep, exactly. These are very big deals in GPU evolution (if not revelation) right now. All GPUs have a HUGE amount of Gflps (compared to a CPU), but how do you control/program the beast to do something more useful than just gaming?
That dedicated L1 cache plays a big role for making the the life much easier to program/control the beast. This makes it possible to have a unified read/write cache, which allows program correctness and is a key feature to support generic C/C++ programs.
Fermi is a complete arch redesign, like g80 & r350. Focus on cache, compute, & gpgpu programmability. cypress is rv770 with alu's & rops doubled and scheduler & setup redesigned to effectively use new resources.
It's not a G71->G80 jump, but it's not a G92->GT200 one either
Not sure if this has been posted before. Card is supposedly the GTX470
http://img.photobucket.com/albums/v4...r/d276985e.jpg
Yeah, it's been posted
It's been posted, but I just checked anandtech's reviews and the 5870 gets 38.5 fps on average I presume, in warhead @19x12 4xAA Enthusiast... granted anandtech's setup has a faster i7 (+130MHz?) but I don't think that's enough for a ~25% increase in frames. I was trying to look for a review with 8x AA but found none atm.
edit:
of course it depends on the part of the game that was ran, but I was thinking they used the built-in benchmarking tool
