Sideeffect -
Thank you for the picks. ok now im gunna sound a friggin retard. but what setting do i switch the tester to. meaning what setting on the Dial do i use ? again i just have never had the need to learn about voltage testers thats why i dont know.
and WHEN do i test this. i mean do i test it when its running prime so i know what the voltage is under load ? and again under idle conditions ?
my point about the X2 and NEO2 is that the neo2 is how old? i mena look, it has enough issues already running the winchesters and newcastles. (most were worked out yes)
But the motherboard is old ok. the X2 is new. its not an old technology it s anew chip from the ground up.
the power demands, the memory controllers, the .... everything about it . just look into a new mobo preferably nforce 4 to make this chip run properly.
seriously look at how certain chips run better overclock better and all around are better on let say the DFI boards with the 4-phase power.
am i wrong ?
12.5v into the 12v line messing up the 12v regulators ? oh come on now i know the posssibility is there but please. The chance of that happening when SOOOOO many psu's come out of the box running over 12v is rediculous. the 12v regulators will handle well into 13v i imagine. i mena sure it COULD happen. but ive seen psu's running 12.3v right out of the box. and reports of ones running higher.
i dont have the balls to push the 12v line higher and no need to do so. The reason i made it 12.5v was to make sure i got 12v on everything and not 11.xx i wanted a nice 12v and 12.5 makes everything run at a reported 12.1v
