Alright thanks man! I will give it a try...
I also see you have a mobile and the XP-120...did you have to mod yours in anyway for it to make good contact?
To be more realistic, 12x300 with mem 1:1 would be da bomb!Quote:
Originally Posted by ugp
I've never seen a socket 754 CPU doing over 3.3GHz so even 11x300 will be elusive to most of us.
Come to think of what 12x300 would do... :slobber:
Now let's not turn this thread into a GF4 next gen hardware performance guess thread. :D
Yeh I sanded the base of the back plate (i guess that's what you call it)... I mean the thing the heatsink sits on.Quote:
I think I almost went too far because putting the XP120 on was quite difficult and nerve racking... but the contact now is great... On full load my CPU sits at 39c... idle is usually 24c-26c :)
What is your CPU clocked at? And you have a DTR right? 82-Watt? or the 62-Watt?Quote:
Originally Posted by Rabbi_NZ
About how much do you think you took off of it?
I'm still tuning her but last night I ran "Prime95 128k-4096k 10hours"/SuperPI 32MB/Sandra/MemTest and all were stable at 10x260 2-2-2-10-1T with 1.75vcore/3.3vdimmQuote:
Max temp during the testing was 41c but sat between 38c-40c most of the time.
I sanded it about half way down... but the way you know not to go too far is, keep trying to sit it flat on your board after every millimeter or so that you sand off (it will sand down very quickly). If you go too far, the two standoffs that come through the back of the board will be too long to fit in the two holes of the "backplate" so it will rock side-to-side... YOU DONT WANT THAT.
So sand down about a mm at a time, then check... if you go too low the "backplate" may also sit on some other small components around the socket... so jus keep an eye out for everything like that and you will be fine :)
Anybody have this board with 5.1 speakers and use the onboard sound?
Yes, works fine for me so far.Quote:
Originally Posted by Godmyster
Well just got done sanding it down...helped alittle but didn't seem to do much really. I am not sure. System is stable at these temps so I guess it is fine. What I really need to do it lap down the Heatsink. Before sanding the backplate down I threw in my old 3200+ and at 250x8.0 it sat at 30C...the mobile sat at 43C at the same clock. Something to me doesn't seem right....
Are you taking these readings from SmartGaurdian? or a probe?
I am going by BIOS...but nonetheless I tried my other CPU and going by BIOS readings they shouldn't differ that much even if the BIOS is off....unless it isn't reading the DTR right...is that possible? It doesn't make since to me at all. But a DTR should run cooler at the same clock speeds right? I am very confused on this.Quote:
Originally Posted by ToastedToad
Same clocks should giv "similar" temps I would think... but remember the readings are from temp readings INSIDE the die... so it is possible they are being READ/MEASURED wrongly with the Mobile... or with the older chip for that matter. Unless you have a probe I wouldnt worry too much... as long as you see no stability issues that is
if your case is filling up with really hot air you know somethings wrong if its all cool then it good
Well it differs at different times...I am unsure...and because I am unsure of the temps I don't want to take it much further. What are safe temps anyway? But I also do not have a probe I can use to check the temps.
put your hand on the heatsink.
If it is too hot to hold it there its running too hot.
No it isn't that hot. I think it is actually fine. I think something just isn't reading right. It seems to be very cool overall in there now. I am even running the side case window back on it and it is working pretty good now. I am going to try to overclock it to atleast 260x10.0 and 1:1 with the same settings in my sig except alittle more voltage on the core.
i just downloaded the last ut nf3 250 beta bios and I made bootable disk with the format tool of windows. I treid to flash the bios but when i run:
awdflash bios.bin
it starts up a program which is going to backup my current bios and at that point the flash utility won't go any further
What should i do ?
:stick:
flash from windows with WinFlash
so, are there any new information about the new winner of DFI? :D
Can someone tell me where to measure VDimm on this board please?
I have a feeling my 3.4v setting is giving around 3.32v under memtest load...
backside of the large mosfet in top right corner of board (above dimm slots).
Cheers dude, can you tell me what pin?
The backside.
There is no pin, its the back... just the base of metal you can see.
Cool, I know what you mean. I'm actually thankful it is that part... less chance of my clumsy hands shorting two pins together.Quote:
Originally Posted by STEvil
Thanks STEvil.
So , flashed my bios succesfully today and i can boot 2650 now in windows , with the stock i couldn't so abit improvement has taken place. I hope they release a new bios soon with a lot of fixes, anyone knows if they are still working on a new bios ?
can someone please link the bios update with memtest86 and 4.0vdimm for this board:help:
