well hey, ill just experiment on this one ;) maybe post a few picks and hopefully get stickied or something like that to show that you should or should not buy it
Sounds good for me:)... Btw what PSU do you have?
Oh crap, I think the extension thing its not going to work, i've checked in Frozen CPU and all the things I need its worth $100+ only the extensions w/o the shipping :( now with the shipping to my country that its gonna be like a lot more and for me thats too much money:down:. I mean i will pay that for the MDPC-X sleeve ;) but for some cable extensions? Any other idea or other place where the extensions dont go that high? I was thinking of buying the connectors and take the cables from the old generic PSU i have all around my house.. will that work?
Thanks in advance!!!:up::up::up:
look for the nzxt pre-sleeved?
Just make your own. Order a spool of 20gauge (or w/e is used) wire, and crimpers (I think their $15-20) is the expensive parts. You can get the pins to crimp on (along with the crimper, I think you get some in a kit when you buy the crimper) from NILS, and get the 6/8/24-pin connectors from frozencpu or whereever
http://en.mdpc-x.com/mdpc-crimping/m...mping-tool.htm
http://www.frozencpu.com/cat/l1/g51/...ml?id=Cus4uYPK
Thanks, i'm gonna look for the 20 gauge wire locally and order the conectors, that way if i have spare (mostly I will) i can make extensions for my other computers as well or save them for another experiment :D
Use 18 or 16 AWG, anything less (ie bigger number) is too thin IMO.
I'd check to see what gauge they are, I'm guessing 18/20/22 range
And you can get cheaper cimpers, but as with all of nils products, they're the best haha
Yea i was actually thinking of buying the crimper along with the sleeve :D. As for the wire i'll get a quote locally, most likely thats the way i'm gonna take to make sure I dont void my PSU warranty because here the 1000HX its close to the $400 USD :ROTF:
18AWG for the usual ATX connectors (20/24 pin power, pciE, 4 pin for CPU, 8pin for CPU, etc), molex and sata power cables too
26AWG for 3-pin fans
Thanks I will take that in mind!
Try chilledpc.co.uk for extensions...they are cheaper and shipping is way way way cheaper than ppcs or any of the other US based stores. I got mine from there...good quality stuff and great service.
Hi! I have a question regarding sleeving somewhat... but it's more related to electric. I was sleeving my PSU, specifically the 8-pin power for the CPU. I removed the old heatshrink, pulled up the sleeve and marked each cable with masking tape so as to preserve the original order. Long story short, I think I might have swapped two of the 12V's, and maybe two of the grounds (a 12V for another 12V, ground for another ground mind you!) Does it really matter?
Thanks a bunch
Attachment 103231
Attachment 103232
Hello, Nils!
Perfect ...
Thanks!
nice tannus cassius!!
lol - Samba-Sleever :D:D:D
http://www.abload.de/img/aquamarinejw14.jpg
samba sleever, kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
I'm laughing too much here!
:eleph: <- Samba
http://img7.abload.de/img/mdpcx-orange-satabucc.jpg
Awesome guide.
