OMG that's just *Out there*:wierd:
EDIT: *didnt see the submerged rad*
Imagine the buildup of deposits computersmsa gets on his rad :eek:
nanobot - probably none, its a sealed system and the well only cools the rad.
Think of it as a water cooled water cooling setup.. lol ;)
That is very insane! I want it! lol
Thought I would post a few pictures of how I mounted my Thermalright XP-120 with 2 120mm Fans. And also you can see the ATI Silencer 3 on my ASUS A9800XT:d
http://www.xtremesystems.org/forums/...id=19771&stc=1
That is just another 120mm wedged into the case between the PSU rail and motherboard tray.
http://www.xtremesystems.org/forums/...id=19772&stc=1
http://www.xtremesystems.org/forums/...id=19773&stc=1
http://www.xtremesystems.org/forums/...id=19774&stc=1
http://www.xtremesystems.org/forums/...id=19775&stc=1
And here is one more picture with the lights off...
Had to make it two posts since of the 5 pic limit at a time.
http://www.xtremesystems.org/forums/...id=19776&stc=1
Zip ties,I love it ! Cuz it's soo ghetto :up:
It was the only way I could mount the 120mm to the XP-120 and since the ZipTies that I have about '300' of are UV Reactive it fits:DQuote:
Originally Posted by Nanobot
isnt it designed for 120mm meaning it would come with clips?
It comes with clips.
so whats ugp thinking?
Maybe he didnt read the manual =)
I am having problems with my slk948U.. at 110% I'm loading at 63C which doesn't seem right.. Would getting an XP120 help my temps?
Does it have enough room to fit without any mods? What load temps do you get at 110% and above?
Thanks.
I have tried mine with 2.0 volts and superpi.
It didnt crash (and it didnt burn either)
Try another bios.
LOL Uber, you really are a high voltage man, aren't you? :DQuote:
Originally Posted by Ubermann
Hehe i just want things to burn so i have to go crying to my girlfriend that my computer dont work any more, so i have no life and must buy new parts..NOW!
I did manage to burn the ATI..but that was when i was drunk.
To bad GF wont let me buy new one =(
So here i am playing halflife 2 with a geforce 2..what a waste of good time.
Btw..the new nvidia 64bits drivers works with xp also (NF3)
Nanabot -> The water is clean :)
Now, I have pickup the rad.
Now, I have submerge a tubing of 3m :)
I love the w/c setup, but why not just just submerge the rad in a bucket of icewater and keep everything together? ????Quote:
Originally Posted by computersmsa
Sorry, I don't unterstand :)
So, it's closed WC ... the water in WC isn't in contact with water of a ... in english ?
I know it's closed, but why not just do the same thing you're doing, except have the bucket of ice water next to your computer and just keep the rad in there when you are benching? This way you don't need to use 5 meters of tubing and lose flow rate. Is that little pump all you have doing this? Unless you run this 24/7 with the cold water? Nevermind me, just do what you were doing LOL
24/7 since one mouth .... ilde 17-19 °C
Farcry -> 24-25°C ...
The fan I have is not able to use the clips...yes I read the manual and no I really didn't need to. It is hard to explain what I mean...it needs clips that will clip on the top of this particular fan because it can't on the lower end of it...
Salut computersmsa !
Ce que je voulait dire:T'on radiateur n'a pas de depot de calcaire cause par l'eau(dure) du puit?
Je vois des depot de calcaire sur les paroies de ciment,donc c'est sur que eventuellement tu vas avoir des depot,non ?
Desole pour l'ortographe mec,j'ai qu'un clavier unilingue anglais.:rolleyes:
*Sorry for the french guys but it's got to be said so he can understand*
are you asking if he's getting limestone deposits on his rad?Quote:
Sorry my bad :shakes:
I should've explained it for the rest of the forum members.
Yes that's what i'm asking him.
go here for translation
http://babelfish.altavista.digital.com/babelfish/tr
so your not the pantswearer then? :lol: :DQuote:
