I took away the ihs from mine, and some as5 on that after lapped the front plate.
Temp stopped going up and down like crazy.
Can give it 2.0 volt without crash, but its kinda crazy =)
listen young man do you want your cpu to end up like that 9800pro? :D :P
thast a good thing to hear. what sinks are u using? i can get 8 tweakmonsters for 20$Quote:
Originally Posted by spaceman
Im not young, im just dont afraid of burning things =)
Not bad man...that is very nice indeed...Quote:
Originally Posted by computersmsa
That is a 62w correct?
Well this is what I think I am going to make my 24/7 Overclock. I am going to tweak this as much as I can. But here is without any tweaking at all so far.
http://www.xtremesystems.org/forums/...chmentid=19743
http://www.xtremesystems.org/forums/...id=19744&stc=1
If anyone sees anything that they think will imporve any of my scores please let me know...
Also...quick question to add...I am wondering about the CPU Temp reading...which do I go by... I am using the 11/15 BIOS.
The BIOS, Smartguardian, and SiSoft all report different Temps...which is accurate?
http://www.xtremesystems.org/forums/...id=19748&stc=1
I'm just using some cheapie CoolerMaster copper RAMsinks. I got em on sale at coolerguys, $5 for an 8-pack. They're located here in Washington state, so shipping for you Aussies might be a little steep. ;) BTW, you better get more than 8, if you want to do them all. I probly used around 16 or 20. You'll see what I mean, when you start looking around. :)Quote:
Originally Posted by reject
Here is a screen...
http://www.xtremesystems.org/forums/...id=19747&stc=1
LoL...it says it is PC4000...it is PC3200 Rev 2 Plat:D
Hey man we can't read the scores...they are too fuzzy fromt he compression. I can see the SuperPi but not the SiSoft scores.Quote:
Originally Posted by trans am
OK, fixed it.
UGP -> Yes it's 62W CG :)
Look my review if you want (French)
http://www.bel-hardware.be/a64moc.html
do the ones with tape pre applied work well?Quote:
What actually states the temps correctly? Does the BIOS?
They work pretty good, yeah. Ideally tho, ya should lap the bottom, & use thermal adhesive. Maybe one day I'll do that. :) ugp, I go by the BIOS, but who knows how accurate any temp readings really are, lol. Even temp probes could be a little off.Quote:
@spaceman: Alright thanks man. Finally someone answered me lol
It's good t° :)Quote:
Originally Posted by ugp
http://forum.bel-hardware.citywebz.c...topic.php?t=62
Look this :)
I can't read any of the text...what the hell does any of it say on that forum?
I'm curious to know what your temps say in the bios. Mine is a 62w also and temps read 40c under heavy load. Is yours anything like this? I'm wondering how accurate that is, since I think all motherboards have issues reporting accurate temps on mobiles and dtr's. It always seens to read about 5c higher or so than actual. Nice o/c man! I've never seen a 3400+ 62w in action until yours.Quote:
Trans am -> The same than SpeedFan ;)
Water of WC @ 13 °C ...
CPU fully 2.7 Ghz -> 28 °C :)
It's normal, water is not @ 30 °C as a normal WC ... :banana:
Thanks man :toast:
http://home.scarlet.be/~pascpiet/DV/PCWC/IMG_0001_s.jpgQuote:
http://home.scarlet.be/~pascpiet/DV/PCWC/IMG_0002_s.jpg
http://home.scarlet.be/~pascpiet/DV/PCWC/IMG_0003_s.jpg
http://home.scarlet.be/~pascpiet/DV/PCWC/IMG_0004_s.jpg
http://home.scarlet.be/~pascpiet/DV/PCWC/IMG_0005_s.jpg
http://home.scarlet.be/~pascpiet/DV/PCWC/IMG_0006_s.jpg
Click
What? This is fvcking nuts man! I've never seen this one before! lol
so your wc setup is in the roof?
No, he has the PC on the 1st floor, the tubes go through the floor into the basement and the rad is submerged in a well in the ground. it must be really cold down there. This should get an award for most innovative w/c setup. He's very resourceful. :)
ahh didnt see second pic
spaceman
im gonna get these 16 for 32$ http://www.zalmanusa.com/usa/product...x=139&code=013
