"No issue with bios below F9?"
No, F7 & F8 work fine, no issues found.
"Any settings overclocked?"
I've tried overclocked, underclocked, and rated speeds for all components with the same results in memtest. I even tried the Crucial Ballistix, rated at 800MHz 4-4-4-12 2.2V, at 800MHz 5-5-5-15 2.2V (underclocked) and still got the same errors with F9. With F8, I can run at 1200MHz 5-5-5-15 2.2V without errors.
"How about running it at default specs?"
Set everything at factory rated spec, still got the same errors in F9.
"Ryouko" alearted me to the issue in post #1823 of the Gigabyte P35 thread (page #73) at XtremeSystems Forums...feel free to read our discussion here (toward the bottom):
http://www.xtremesystems.org/forums/...142340&page=73
He has had similar results:
"I have been running memtest86+ on it (usb legacy disabled) with 3 different sets of corsair CM2X1024-6400C4 and then I tried the Crucial Ballistix BL2Kit12864AA804 and they both failed, both with using the pc35-ds4 default configuration, and with the optimized configurations that are recommended by the memory companies website."
