Originally Posted by jcollett69
A few thing about RAM. Most "manufacturers" do not make the chips themselves. Rather, the purchase the chips and PCB on the open market, test them to certain timings and speed, and sell them as their own. Any particular line of RAM could have different types of chips in them depending what was available on the market at the time. Sounds line you may have RAM that was produced from Winbond dies, the older set most likely being BH and the newer most likely CH. BH is well known for not booting into CAS 3 but will do 2.5 or 2.0 with proper voltage. Get that vDIMM up into the 3.2 to 3.3 range and you may find that your RAM can do 2-2-2-5 at fairly high speeds (~250MHz). I know the MSI board will not do that voltage. A vDIMM hack or OCZ DDR booster would correct that issue for you.
As far as having four double-sided DIMMs populating your motherboard's RAM slots...this will always cause your BIOS to revert to DDR333 speeds. Search these boards for much of this knowledge being repeated over and over ad nauseum. OK, I'm done here.
Hoping for that new BIOS :shrug:
