Hi, anybody use the DFI onboard sound? i cant get the 5.1 to give, i can only get 3 speakers and the Subwoofer or 4 speekers without the center speeker and the Subwoofer.. antbody have any ideia or of some program that can make this work? Thanks :)
Yeah get rid of it and use a Audigy 2 ZS
its good. good quality but lags cpu time
i use a sb live 5.1
my unbuffered at 280 is like 2250/2350 and thats with loose timings... eva2000 had i think 2500/2600 with 2-2-2 and about 255 HT, your timings are bad try 2-2-2-10 and it might go up
I use it,don't have any prob's with it,works and sound real good,i use also a Logitech Z-640 speakerssystem(5.1),use the prog that comes with it Xear3D and works great,nice soundeffects :cool: you,can/and i'did,make with it;).Quote:
Originally Posted by Godmyster
Dont have that Xear3D Program in the Lanparty CD =| any idea where i can get this?
Unbuffered in sandra ?Quote:
Originally Posted by reject
2-2-2-0 gave me 2034. I havent touched anything othert han cas, trcd, trp and tras.
well something is wrong. what is your cpu speed? i know that affects memtest bandwidth a lot, evas cpu was about 2.6ghz
try tweaking some of the low level settings, like Tref, set that to 4708, 4196 or 3120. i think the latter is good for bh-5 according to jess1313
set the 2 second last timings to 4x 4x that works best for me, but you might also try 7x 16x
Xear 3d sucks i had it on my epox nf2 its a crappy program.
get a sb live there about the same as onboard, but dont use cpu up and also have eax
9x250. 2800+ clawhammer with 512k L2 ;)
Given the CPU speed its not bad i'd think? Good enough for 38s super-pi anyways. Beats 2x512 of CH-5 by 2 seconds @ 248 1.5-2-2-10
Just got my 3400+ DTR and it is this..
AMA3400BEX5AR
CAABC 0411MPM
Time to slap it in and see what it can do... :D Wish me luck:D
That's a very early week you have there (early March 2004). I hope you can pull something sweet out of it. Let us know how it goes.Quote:
Originally Posted by ugp
:toast:
Got my new 0433 3400NC and tested a bit with 1 module of OZC PC4200...
http://www.forumdeluxx.de/gallery/da...83_divider.JPG
Not too bad, but with 9x300 and 9/10 divider for ram... all air cooled.. btw does 2600 on stock voltage
For 2750 I need 1.75vcore :mad: , pi suddenly decreases to 34 sec :confused: and temps go thru the roof with 52c under load :(
I.E.: Good chip, but need Vapo for new highs ;)
Alright first results after not even changing anything from my old setup but to a 10 multi.. so I am at 2.5:d at v1.6 on the core... with my XP-120 as well:-d
I got 7582 on 3DMark03 so far...I have alot of tweaking to do...although it could be my driver as well.
Right on ugp! :cool: What, no pics of the lapped 120? :D
I didn't even get to lap it yet, the heatsink is stock. I will eventually lap it down.Quote:
Originally Posted by spaceman
yeh stevil that ram id awesome in superpi, i get 38s and 37s at 270x9
i was playing hl1 for about 3-4 hours. then it crashed, so i upped voltage from 1.75 to 1.76 and that should do it. i was also folding at the time.
heat plays a big part in instability for me. as long as i have my cpu fan on full and rear fans on about 1/3 speed, its ok.
im gonna invest in some mosfet cooling that will do good for my cpu and i might get phase, although im thinking of getting a dothan and dfi :P
Here is my current records on SP1M and 8M on WinXP Pro 32bit:
DFI LP 250GB, 3200+ 130nm (CBAEC 0428RPMW)
http://koti.mbnet.fi/dani69/DFI%20nF...XP%2032bit.gif
Most testing done alittle...MemTest86 stable atleast...
Highest the CPU Temp reached 52C
Me thinks I can go further!:D
Here is my AquaMark3 score..
http://arc.aquamark3.com/arc/arc_vie...run=2028695414
55,802...Time to tweak alittle more. I went back to 250x10.0 because I don't believe 260x10.0 was 100% stable. Have more tweaking to do:-d
My new CPU cleared all my troubles...
http://www.xtremesystems.org/forums/...id=19676&stc=1
Only at default voltage and 2,9V at the RAM.
Heading to bed right now, but will be back tommorrow with more results. :)
You can sleep well now Zeus =)
Finally some fun!
New CPU cleared all my troubles so far as well:D
Nice, Zeus! :toast: Hey guys, don't forget to sink up ALL your MOSFETs. I've been havin some weird probs OCin, & decided to pull the mobo last night & start over. Seems I missed a couple MOSFETs before. :rolleyes: There's one near the edge of the board by the DIMMs, and another near the ATX header. After sinking them, all my temps went WAY down. I'm runnin' my 3200+ now @ 2400 MHz.(10x240) @ 1.6vcore, and temps are 29c, 22c, 22c idle. :D
I don't really have any heat issues...there is hardly any heat at all in my case now:D
