first sorry for my bad english
System Specs:
CPU: Core 2 Quad Q6600@3.4GHz@1.264V
Mainboard: ASUS P5Q-E Bios: 1406m
RAM: 2GB OCZ Reaper 1066@1133
GPU: ATI HD3850 512MB
Power Supply: be quiet! Straight Power 550W
OS: Windows XP SP3
Detailed Infos:
http://www.sysprofile.de/id13681
Bios Settings:
Code:
BIOS 1406m - Q6600 mit 3400 Mhz
.:AI Tweaker:.
AI Overclock Tuner [Manual]
CPU Ratio Setting [08]
FSB Frequency [425]
PCI-E Frequency [100]
FSB Strap to North Bridge [Auto]
DRAM Frequency [DDR2 - 1133]
DRAM CLK Skew on Channel A1 [Auto]
DRAM CLK Skew on Channel A2 [Auto]
DRAM CLK Skew on Channel B1 [Auto]
DRAM CLK Skew on Channel B2 [Auto]
DRAM Timing Control [Manual]
1st Information : 5-5-5-15-4-60-6-4
CAS# Latency [5]
DRAM RAS# to CAS# Delay [5]
DRAM RAS# Precharge [5]
DRAM RAS# Activate to Precharge [15]
RAS# to RAS# Delay [4]
Row Refresh Cycle Time [60]
Write Recovery Time [6]
Read to Precharge Time [4]
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Enabled]
AI Clock Twister [Strong] >Moderate *
AI Transaction Booster [Manual]
Common Performance Level [8]
Pull-In of CHA PH1 [DISABLED]
Pull-In of CHA PH2 [DISABLED]
Pull-In of CHA PH3 [DISABLED]
Pull-In of CHA PH4 [DISABLED]
Pull-In of CHB PH1 [DISABLED]
Pull-In of CHB PH2 [DISABLED]
Pull-In of CHB PH3 [DISABLED]
Pull-In of CHB PH4 [DISABLED]
******** Please key in numbers directly! ********
CPU Voltage [1.36250] --> real: 1.264V
CPU GTL Voltage Reference (0/2) [0.645]
CPU GTL Voltage Reference (1/3) [Auto]
CPU PLL Voltage [1.50] >1.54 to 1.56v *
FSB Termination Voltage [1.30]
DRAM Voltage [2.12]
NB Voltage [1.32]
NB GTL Reference [Auto]
SBridge Voltage [1.10] >Auto *
PCIE SATA Voltage [1.50]>Auto *
Load Line Calibration [Disabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Performance Mode]
I have a big Problem. I cant get my system stable with manual choosed strap. WTF? But with Auto + Strap 400 Memory divider it is stable but the Memory is too high overclocked, because i have to choose Strap Auto and DDR2 - 1133 (850 would be also possible but it isnt in the list to choose) for stability otherwise prime large error. If I choose Strap 400 + DDR2 - 1133 or 851 = BOOTLOOP ?! WTF ?!
Is that a Bios bug or what? It is so:confused: because 1133 is a Strap 400 divider!
Its also with the original Asus Bios!
For example
Strap 200 - Prime Large Errors (Memtest Error Test 5 after 0.5 min)
Strap 266 - Prime Large Errors (Memtest Error Test 5 after 0.5 min)
Strap 333 - Prime Large Errors (Memtest Error Test 5 after 0.5 min)
Strap 400 - BOOTLOOP Why I can't choos Strap 400 manual ? o0
Strap Auto - !Prime Custom STABLE! but Errors in GoldMemory <-- I cant solve these Problems with Timings or Dram Voltage Any conclusion? Why i have these little Errors? Why i can't get get Strap 333 stable ?!
I also tested all these Settings:
Strap: Auto + DDR2 - 851 --> Memtest Error Test 5 after 0.5 min
Strap: Auto + DDR2 - 1021 --> Memtest Error Test 5 after 0.5 min
Strap: Auto + DDR2 - 1066 --> Memtest Error Test 5 after 0.5 min
Strap: Auto + DDR2 - 1133 --> No Prime Large Error, but 1 GoldMemory Error
Strap: Auto + DDR2 - Auto --> Memtest Error Test 5 after 0.5 min
higher isn't possible
I hope you can help me!
THX
