Nice score mate :up:
Cheers
Sergio
Here you go :up:
http://www.xtremesystems.org/forums/...=203236&page=7
Tanx M8 For Guide Me
And Tanx For See My Resualt
Nice scores Sergio and ViViD but I can't let you two have all the fun.:)
http://i306.photobucket.com/albums/n.../th_fastpi.jpg
The GPU just didn't want to clock like it usually does but anyway. http://service.futuremark.com/compare?3dm06=11128533 (only did 830/2050/2500 instead of the usual 850/2100/2500:shrug:)
http://img512.imageshack.us/img512/3874/desktopl.th.jpg
My successful overclock on air with a Zalman 9700NT. My idle temps are around 34 and my full load temps is about 60.
thinking of getting a q9650 and hoping for 4ghz
are the recent batches/weeks overclocking ok
im pretty sure they will all do 4.0Ghz
i can safely guarantee 4.0Ghz and higher with the UD3P/UD3R boards
Thanks. :) From the looks of what is in your signature you wouldn't have any cooling problems with more volts.:up:
Thank you.:) The cooling is a custom watercooling system with a 240MM radiator. After 15-20 minutes of benching the liquid temperature gets high enough that it takes about a half hour of rest before it will run with any kind of stability. :rofl:
Thanks man. I learned a lot from your various posts in this section.:up:
seem to be having problems getting my Q9650 prime stable
it passes linpack at 4.05Ghz 450x9 @ 1.28 vcore
but core 2 fails prime within 2 minutes and ive tried going all the way up to 1.35v
NB and VTT at 1.36v
using a maximus ii formula
anyone got any suggestions?
thanks
Had my Q9650 disabled for a long time now.
I will hook it up tomorrow to get the 9.3 Super Pi back so you have some seconds to live for :up:. I didn't save the entire pi run because it was a lousy run and never thought it would beet the World Record.
And XS erased my post of last stable OC (IBT and Prime95) 4700Mhz 1.39-1.40vcore. Too bad had some good pointers there.
Here, no tweaks, this is on regular Win 7 OS that I used daily (no wazaa, fresh install etc etc).
http://i42.tinypic.com/286v3f6.jpg
Thanks, catching that is going to quite the challenge.:up:
I used the same clockspeed on a cut down XP and you still killed my time.:rofl:
http://i306.photobucket.com/albums/n..._untitled1.jpg
How to get this to run at 5GHz..Hmm...
The laughable advanced memory timings are the difference between a very stable 4.85Ghz and a rather unstable 4.9Ghz. For 4.85Ghz i could use Performance Level 11 and much tighter timings all around.:up:Code:Robust Graphics Booster - FAST
CPU Clock Ratio - 6X
CPU Host Frequency - 545 or 556
PCI Express Frquency - 103
C.I.A.2 - Disabled
CPU Clock Drive - 1000mV
PCI Express Clock Drive 1000mV
Clock skews are all set to 0PS.
****DRAM Performance Control****
Performance Enhance - Standard
Extreme Memory Profile - Disabled
(G) MCH Frequency Latch - 400MHz
System Memory Multiplier - 2.00
DRAM Timing Selectable - Manual
>>>Sandard Timing Control<<<
CAS Latency Time - 5
tRCD - 5
tRP - 4
tRAS - 15
>>>Advanced Timing Control<<<
tRRD - 15
tWTR - 15
tWR - 31
tRFC - 255:eek:
tRTP - 15
Command Rate - 3
>>>>Channel A Timing Settings
Static tRead Value - 15
Everything else is Auto.
>>>>Channel A Driving Settings
Driving Strength Profile - OC-1200
>>>>Channel B Timing Settings
Same as Chanel A.
>>>>Channel B Driving Settings
Same as Channel A.
****Motherboard Voltage Control****
>>>>CPU
Load Line Calibration - Enabled
CPU Vcore - 1.60000V
CPU Termination - 1.660V
CPU PLL - 1.810V
CPU Reference - 1.036V
>>>>MCH/ICH
MCH Core - 1.660V
MCH Reference - 1.051V
MCH/DRAM Refence - 0.920
ICH I/O - 1.750V
ICH Core - 1.300V
>>>DRAM
DRAM Voltage - 2.100V
DRAM Termination - 1.050V
Channel A Reference - 1.050V
Channel B Reference - 1.050V
CPU Features are all Disabled.
well just an update of my SPI 1M :) just for fun
http://img132.imageshack.us/img132/9228/spi12.jpg
cheers :up:
Sergio
Holy crap! Sick FSB for quads! Well done, mates !
Hey guys,
Inspired by thebluemeanie1 I decided to go for the 7 Gold Cups available for Q9650 hardware: CPU-Z, PiFast, SuperPi, SuperPi32m, wPrime32m, wPrime1024m and PCMark05. I got 6 out of 7 so I think it's an interesting read for Q9650 owners:
Q9650 - 6 Gold Cups in one Day (conquering the HWBot HOF)
Very very impressive times with clock speeds to match. The CPUz, SuperPi 1M, 32M and PiFast are completely untouchable.:shocked:(By me anyways)
Does going colder help with the FSB speed?
Once I saw your post I got right to reinstalling windows and running wPrime.;)
http://i306.photobucket.com/albums/n...prime1024M.jpg
Hey Bluemeanie I see you have some backups :up:
Well yeah those are still on the works I don't know what should I do to optimize wPrime, it's a new engine to me, I dunno how come my scores with hiegher ram speeds are lower, obviously I'm doing something wrong. I probably can get lower scores on Vista I only tried on Xp and W7 I would hate to format my PC right now...
The temps always helps but my SuperPi scores I did with water. wPrime1024m is a real cooling system test after it passes 80%!
