Originally Posted by
vab206
w00t finally got my rig stable @ 1:1 ratio, running 533FSB w/ 7.5 multi, (dosent like 8) only changed the bare minimums from auto like dram timings, pl, fsb, cpu ratio. voltages are:
CPU Voltage: 1.35000
CPU PLL Voltage: 1.60600
FSB Termination Voltage: 1.25900
DRAM Voltage: 2.10475 (as listed on my ram)
NorthBridge Voltage: 1.35175
CPU GTL Refrence (1): +40mV (left this setting from previous OC, could probably set it to auto as well)
Dram Static Read, Dram Read Training, Load Line Calibration, CPU Spread Spectrum, PCI-e Spread Spectrum all set to disable.
PL is set to 10 (lowest i can get it /sadface)
Mem OC Charger is Enabled
Clock twister is set to moderate, ive never been able to boot with anything over that, anyone have a suggestion on what i can change to get to to strong or stronger, every other setting is set to auto.
May try 1.4 or 1.45 vcore tomorrow to see if i can get it 533x8 stable, temps are @ 66C under full load, 50C idle... if it raises too much w/ that vcore i may just wait til i get my SS running.
man its gonna be a pita to insulate this board... /facepalm
