I put this link here.
http://www.xtremesystems.org/forums/...2&postcount=22
My own
http://www.xtremesystems.org/forums/...1&postcount=23
It explains alot.
I prefer "the cold method" than the "warm" one.
My own
It explains alot.
Will these boards do 500fsb easily??? My MIIF is having trouble doing so...
It'll void warranty I believe.
All you need to remove it is a sharp wood chisel and a hammer. Lightly tap the chisel around the glue to break the bond and the heat pipe should come off. Getting it off the southbridge sink is easy. The chisel is more needed for the NB sink, so you dont damage the sink when removing the stubborn bastard of a heat pipe :D
Thanks for all the replies in regards to the removal of SB/NB heatpipe, doesn't that sound that hard at all. I assumed the heatpipe was soldered onto the heatsinks not glued, in this case I'm glad its not soldered! Thanks A-Grey for your thoughts about the warranty, they probably take it on a case by case basis. I'll report back if/when I try removing my heatpipe and if I see any temp changes. I was also thinking about removing the ROG logo on the SB, it looks like removing that might help a bit with temps (but the difference might be negligable)?
neo rtr - Thanks for posting those links, very interesting! I wish I read that back when I first got my board because the first thing I did was completely remove the heatpipe assembly to replace the thermal paste and make sure everything was seated properly. Just like you noticed my stock thermal paste was rock solid and made very poor contact with the heatsinks so I'm glad it was the first thing I did. I think its a good practice to do this with pretty much any new motherboard (although some seem to be better than others).
I received some information today from my contacts at ASUS. They will verify the problems internally that we found with BIOS 0802.
Yes, I think they do that. A lot depends why you have to RMA the board. When it's because you broke something on the board trying to remove the heatsinks you'll definitely void your warranty.
Removing the ROG logo on the SB might help a bit if you've got good air flow in your case. The plastic cover keeps the air flow from the heatsink. I don't expect huge temperature difference but every degree lower is a gain.
GregGun got his board last week. He told me that it didnt have thermal paste on the SB and NB.
Instead it had the same thermal pad as the moffsets.
If we can confirm that as well with another modo will be great.
So i would think that, ASUS knows, what people are doing (removing the heatsink) and took a step to the right direction making it easy for both them selfs and the users.
Zucker2k can you tell me what core you have trouble with. Sometimes I've got trouble passing Prime95 Small FFT's. Core #2 fails sometimes in Small FFT's.
I wonder if that is because of the voltage fluctuations from the vtt or if there is something wrong again with the CPU GTL's.
If voltage is fluctuating you need to isolate the problem. Make sure the PSU is able to handle the load at that voltage. Could be the VR on your board is failing too. I'm pretty sure mine isn't nearly as competent now as it used to be. If core is failing also raise the PL + 1 and see if that helps.
You think one core failing at high overclock is an issue! HAH! I'm getting a headache trying to find stable DRAM timing values on this DFI board heh. Playing with CLK/DQ drive strength at the moment because I'm getting instabilities few hours in. Also playing with DRAM DLL skew models, apparently DFI don't have the models for DDR2 listed anywhere so i'm playing guess who!
Heya all.
First post but long time lurker.
I'm having a problem which I'm draging from my Maximus Formula MB and now it is present on Rampage too. I have 3 HDs (2xSeagate 320 in RAID0 + 500GB WD) and Pioneer DVR-216 SATA DVD Burner all connected to ICH9R. Seagates are on ports 0 and 1, WD is on 2, Pioneer is on 5. Vista x64 installs fine but after some time raid fails or WD is missing from drive list. I can make it fail almost instantly after clean install if I watch few movies from DVD. So I narowed it down to SATA DVD. I've used old IDE Pioneer DVD on JMicron and could not replicate the error.
Since the first time I've encountered this problem I've changed all components including MB, DVD, and few BIOS versions. Only same component are those two Seagate disks. Are they a problem? Will changing them with differend brand/model HDs solve it? Or is RAID+nonRAID+DVD on ICH9R mission impossible?
Well...here are my bios settings with which i can pass 5 passes with half memory stressed succesfully and that with my new(replaced) QX9650 and the new Rampage board:
Ai Overclock Tuner : [Manual]
CPU Ratio Setting : [8]
FSB Strap to North Bridge : [AUTO]
FSB Frequency : [475]
PCI-E Frequency: [105]
DRAM Frequency: [DDR2-1141]
DRAM Command Rate : [2N]
Dram CLK Skew on Channel A : [AUtO]
Dram CLK Skew on Channel B : [AUTO]
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : [AUTO]
Row Refresh Cycle Time : [AUTO]
Write Recovery Time : [AUTO]
Read to Precharge Time : [AUTO]
Read to Write Delay (S/D) : [AUTO]
Write to Read Delay (S) : [AUTO]
Write to Read Delay (D) : [AUTO]
Read to Read Delay (S) : [AUTO]
Read to Read Delay (D) : [AUTO]
Write to Write Delay (S) : [AUTO]
Write to Write Delay (D) : [AUTO]
DRAM Static Read Control : [AUTO]
Ai Clock Twister : [AUTO]
Ai Transaction Booster : [Manual]
Common Performance Level : [08]
CPU Voltage : [1.43]
CPU PLL Voltage : [1.50v]
North Bridge Voltage : [1.51v]
DRAM Voltage : [2.12]
FSB Termination Voltage : [1.44v] 1.36v real
South Bridge Voltage : [AUTO]
SB 1.5v Voltage : [AUTO]
Loadline Calibration : [Disabled]
CPU GTL Reference : [0.63x]
North Bridge GTL Reference : [0.67x]
DDR2 Channel A REF Voltage : [AUTO]
DDR2 Channel B REF Voltage : [AUTO]
DDR2 Controller REF Voltage : [AUTO]
NB LED Selection : [NB Volt]
SB LED Selection : [SB Volt]
CPU LED Selection : [CPU Volt]
Voltiminder LED : [Up to you]
CPU Clock Skew : [200]
NB Clock Skew : [100]
During the burn test my vcore was exactly@ 1.32
Before, i had fsb@1.42, cpu nb skew and cpu nb gtl were untouched and i couldnt pass the burn test. Now i will try to fine tune everything and see which the lower volts i can run 475fsb @ 3800mhz.
Rampage Formula BIOS 802, Intel Q9550 C1 @ 4.01Ghz, Mushkin Ascent 4x2Gb XP2-8500 (996619) cooled with a ZEROThrem FZ120 in a Antec P180 case. I didn`t had much time to stress it to the limit. I hope I have some time for some IntelBurnTest tomorrow.
Idle - 43 grade
Fulload (Prime95) - 65-68grade
CPU-Z ValidationCode:ASUS Rampage Formula BIOS 0802 Template
*Extreme Tweaker*
Ai Overclock Tuner [Manual]
CPU Ratio Setting [08.5]
FSB Strap to North Bridge [333Mhz]
FSB Frequency [470]
PCIE Frequency [100]
DRAM Frequency [DDR2-941MHz]
DRAM Command Rate [2N]
DRAM CMD Skew on Channal A [Greyed Out]
DRAM CMD Skew on Channal B [Greyed Out]
DRAM CLK Skew on Channal A [Advance 300ps]
DRAM CLK Skew on Channal B [Advance 300ps]
DRAM Timing Control [Manual]
1st Information
CAS# Latency [5]
RAS# to CAS# Delay [5]
RAS# PRE Time [5]
RAS# ACT Time [15]
RAS# to RAS# Delay [3]
REF Cycle Time [50]
WRITE Recovery Time [6]
READ to PRE Time [3]
2nd Information
READ to WRITE Delay (S/D) [8]
WRITE to READ Delay (S) [3]
WRITE to READ Delay (D) [5]
READ to READ Delay (S) [4]
READ to READ Delay (D) [6]
WRITE to WRITE Delay (S) [4]
WRITE to WRITE Dealy (D) [6]
3rd Information
WRITE to PRE Delay [14]
READ to PRE Delay [5]
PRE to PRE Delay [1]
ALL PRE to ACT Delay [6]
ALL PRE to REF Delay [6]
DRAM Static Read Control [Enabled]
Ai Clock Twister [Light]
Ai Transation Booster [Manual]
Common Performance Booster [8]
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHA PH5 [Disabled]
Pull-In of CHA PH6 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
Pull-In of CHB PH5 [Disabled]
Pull-In of CHB PH6 [Disabled]
CPU Voltage [1.3000] real 1.288
CPU PLL Voltage [1.50] real 1.552
North Bridge Voltage [1.33] real 1.2
DRAM Voltage [2.00] real 2.0
FSB Termination Voltage [1.30] real 1.32
South Bridge Voltage [1.05] real 1.056
SB 1,5V Voltage [1.50] real 1.502
Loadline Calibration [Enabled]
CPU GTL Voltage Reference [0.63x]
NB GTL Voltage Reference [0.67x]
DRAM Controller Voltage REF [AUTO]
DRAM Channel A Voltage REF [AUTO]
DRAM Channel B Voltage REF [AUTO]
CPU LED Selection [CPU Voltage]
NB LED Selection [North Bridge Voltage]
SB LED Selection [South Bridge Voltage]
Voltiminder LED [Enabled]
CPU Spread Spectrum [Disabled]
PCIE Spred Spectrum [Disabled]
CPU Clock Skew [Delay 100ps]
NB Clock Skew [Normal]
*Advanced settings*
C1E Support [Disabled]
CPU TM Function [AUTO]
Vanderpool Technology [Enabled]
Execute Disable Bit [Enabled]
Max CPUID Value Limit [Disabled]
Intel(R) SpeedStep (TM) Tech. [Disabled]
I think I am as tweaked as I can get with this mobo and cpu with 8GB of RAM. I have it stable with the settings in my sig and I have the memory set to PL 7. I took out one of the X2 video cards and it didn't make any difference. I am satisfied with this oc on a quad running 8GB.
