3.6 -3.8
If someone needs to make a bootable USB drive, follow these instructions here. I used this to make a bootable USB for video card flashing.
http://www.techpowerup.com/articles/...g/vidcard/34/5
Does anyone know if the TRUE 120 fits in either orientation on the x48 LT ?
Yeah has anyone fettled the new bios yet or have you downgraded back to a older one as i can`t seem to get 4005Ghz stable on the 714 bios for some reason.
new bios not stable enough for me to play with
i'm runnin ut x48 602 its good enought till dfi makes a better stable bios
nogood i'd actually consider a q6700 over a q6600
i got a feeling only the p45 chipset is actually better for 45nm quads
me i lookin forward to an e8600 or e8650
I hope Clunk will add these new feature in his guide soon
Isn't much to post a guide about. DS/DDS are memory drive strengths. Use no stronger then necessary to stabilize the ram. DDL Mode models are for different types of ram. Experiment to find which model works best.
that 1 is easy to figure out i asked u before what is strongest 1 or 8
we need help with gtl xtra settings that are in hex
wtf would dfi just make it hex lol yes i know bios in hex but oscar should make a guide or something cause that gtl mch combination is infinite n verry hard to figure out unless your a coder lol
i'm not a dummy but i no genius either :rofl: if i were i'd write me a bios:D
Anand's review of this board has some recommended MCH settings.
this is from anantech
MCH Vref 1/2/3 Value
The defaults for these three settings are 00/00/80. DFI informed us that all three settings must be moved in unison, i.e. the ratio between all three settings should be maintained if making any adjustments. Up to 500 FSB, adjustment of these three settings is not usually necessary (though the FSB threshold for required adjustment may be lower for quad-cores). Unfortunately, there is little information available to us as to exactly which part of the MCH is driven by these reference voltages.
However, through some fiddling, we have found that a value of 30/30/B0 works quite well on our board once beyond 500FSB with a 45nm dual-core CPU. Effects can be marginal at times and at others provide the MCH with enough offset to boot into the OS and allow a benchmark to run. With a hexadecimal scale ranging from 00 to FF, the permutations for adjustment are almost limitless.
We found values over 40/40/C0 did not provide us with any additional gain. Properly set, the ability of the board to run low levels of VMCH may become apparent for those who run just benchmarks. We managed to 3D benchmark our board right down at 1.4VMCH at 500FSB and 4GHz with an E8500 CPU with 4GB of memory when this setting was tuned for our board and parts combination, something we have not be able to do on any other X48 board in DDR2 form.
ok so 30/30/b0 for 45nm
it would be nice to have a little help
The higher the number the higher the drive strength. I think I've already mentioned that it is best not to adjust the 6 MCH values. In my opinion they should not have been unlocked for the public. I have conveyed this to DFI and will continue to do so. Maybe with the next BIOS release these will once again be hidden.
Take a look over here: http://translate.google.de/translate...hl=de&ie=UTF-8
Translation is very bad but I hope it's understandable.
Problem is DS/DDS levels are not completely user selectable. When changing default values of 8 to 6 they revert back to 8 automatically. After a CMOS clear running default settings changes to DS/DDS have been saved but after adjustments that's no longer the case.
This new bios is a keeper for me. Gets me my clocks with slightly lower Vcore and Vnb.
Axis
