With that ocz ram try setting the ddr v to normal. With that setting I can get 480+ on the ram no problem by setting it up at all (+.1~.4) I can't even get the ram to reliably do more then 390 anymore.
You have a revision 2.0 DQ6?, when and where did you buy it?...can we get pics of the mobo?, whats been chnaged/update on the layout?
b0bd0le if I'm not mistaken that ram you have is D9, try the new beta bios that ken just posted, that should help you out.Quote:
Originally Posted by b0bd0le
awesome, seems like it might be more stable now...Quote:
Originally Posted by Richard Dower
it's last longer in orthos at least
i am booting up @ 1.425v, than using easytune to make it 1.45~1.475
and i noticed that when anything above 1.46, cpuz reports 1.213v...
intel's TAT or core temp is reporting 78c for core1 & 75c for core2
i wonder if heat could be an issue, luckily i have a infinity sitting right next to me :D
oh sweet, thanks for the heads up friend :toast:Quote:
Originally Posted by SnakeEyes
edit: ouch core1 is @ 80c...
It's funny actually. Look how many goodies hang out on 16. :DQuote:
Originally Posted by Lestat
http://img.photobucket.com/albums/v212/jodiuh/irq.jpg
The sound card's hanging out with the USB controllers. I think I'm gonna flash the bios from windows without resetting the cmos jumper this time...
Thanks for F8 beta Ken.
Naa the rev 2 was for that whole 2 versions of the F6 bios...
How the hell are you getting such a high temp. That's obviously the problem :eek:Quote:
Lots of back and fourth tech suport messages between me and GB in regards the SYS_FAN issue. They now say they've passed on all messages and will test to see if they can replicate the issue, in addition they sent me this beta bios:
http://ggts.gigabyte.com.tw/FileList/407862/965pdq6.f7a
Obviously the same as Ken posted, but an "official" link none the less.
I didn't think they released any F7 betas before? Ken posted a F8a!Quote:
Ken upped F8a for the DS3, this is F7a for the DQ6.
um......I uploaded this too....Quote:
Originally Posted by kenofstephen
and this......Quote:
now running at 420 wasnt able to be orthos stable at that before, i was only able to run at 415, but now i cant get pass that whats wrong, i am runing at 1.381v and tried to increase it and no luck, and ram is at 2.2v increased it to 2.3, no luck, loosened timings no luck, i have a week 28 e6400 and crucial ballistix DDR 800 ram, 2GB of it, why cant i go any more? what am i doing wrong? btw im runing windows x64. and i have a DS3 and 8a bios
oc is not guaranteed, maybe you are having a crappy CPU.Quote:
Originally Posted by gooface
can someone confirm the xfi fix is in f8a also
I flashed back to F4 for now until its fully resolved.
so lazy :stick: :slap: :slapass:Quote:
Originally Posted by Dazog
that temp is measured @ the core itself... according to windows it was really 49cQuote:
Originally Posted by IvanAndreevich
hmm i thought this ocz was elpida memory?Quote:
are you sure it's D9? that would be awesome!
Bf2142 came out today
I need a working sound card to Pwn some noobs.
Try 1.200v you will see itQuote:
Stalk3r
Doesn't happen to my E6400/DS3 when I set vcore to 1.100V (temps fell 5C actually).
finally it solved with new release?Quote:
Lestat
and hamid you will wait for F8 just like the rest of us are, i been waiting since the day this baord was released for the D9 fix so back of the bus son and wait just like the rest of us.
they have been working on this issue for awhile now and you should be happy that they have it fixed. they are just tweaking the bios.
whats your memory? Patriot 800? SL EP??Quote:
ScythedBlade
Wait ... has the D9 memory fix happen yet? I still can't get my ram above 438 stable .... its patriot too ...
:slapass: I flashed mine and put in at least 5 hours of BF2142. Going to work on an hour's zzzz'z fun!! Dell 2007FPW comes in today, should be good times...especially since my sound card's not disappearing anymore.Quote:
HamidFull: No, my memory is the Patriot 5300 .... although it runs at 438 FSB perfectly stable 24 hours at 4-4-4-9, with the F8a BIOS, i can push it up to 450 FSB and failing only an hour later on the ram stressing test ... what timings should I use? ...
So far it seem to be working with the F8a bios. I haven't lost it yet since I tried the bios.Quote:
Originally Posted by Jodiuh
ok thank you for the picture.
can you now tell me what USB devices you have running that might be messing with the XFi ?
and like i said look at those IRQ placements . look at how many resource hungry items are all on the same IRQ. does gigabyte really think, or any manufacturer really think that issues arent going to happen ? you cant shove that many key hardware(s) on 1 irq... thats too many resources to have on 1 IRQ.
