Well I don't know about stock, but at 3.8 GHz @ 1.17v idle is about 30-32ºc and load is no more than 59-61º with my i7 and the Megahalems.
I've checked the blackplate, is secure. I'll do some more testing, if not solve the problem, I'll end up replacing the other cooler.
Because I've installed four times the cooler, and the problem still persists. The problem is whether the CPU (I don't know) or the cooler.
What do you think?
Hows the contact look when you remove the cooler?
Got pics?
Photos I don't have, but I will provide.
After I read the manual cooler with calm, I saw that I installed a piece called "rubber inlay" along with the backplate, this one:
http://img441.imageshack.us/img441/4050/rubberinlay.png
This "rubber" is installed only with the socket 775, perhaps to get over it, the problem may be the temperature of the processor, because without this "rubber inlay" sink would have more contact with the processor, correct?
How are you going to corrupt the board bios by removing a rubber grommet? You need to shut the system down then remove power via unplugging the cord to the psu or switching off the unit in the back. Then remove your inlay piece. LOL
Figured I should make a contribution since I just got myself a 920 D0.
3910A250
Stable at 3.72GHz, 177x21, HT always on, stock vcore (cpuz reads 1.28v under load)
Max temps across cores 69-74C.
This is fine for me, not interested in 4GHz. :up:
When the processor was with the high temps (50~55ºC idle clock stock), I updated the BIOS thinking that would solve the problem, but to no avail. Then I want to go back to the BIOS version of the original P6T Dlx (0804) through the Asus Update and could not. That was when I managed to update the program AFUDOS, and from there system did not call more.
4000Mhz, 1.182v
http://www.imagesforme.com/thumb/thumb_59b28c3f.jpg
Lot of people here just need a low voltage to get to 4.0Ghz mark but mine requires a lot more (ie 1.33 to be stable at 4.0Ghz). At first I thought my chip sucks so I went to buy another D0 and got it 4.0Ghz stable at 1.2 but since I couldn't even reach 4.2Ghz stable with it, I think the decision to keep my old one is a good choice. Changing from air cool to watercool is a huge improvement as well since I only got it to 4.0Ghz with the TRUE/MegaShadow but now I can run at 4.5Ghz LinX stable with my new WC setup.
Batch #: 3912B168
4.2Ghz with TRUE/MegaShadow:
http://img406.imageshack.us/img406/96/linx42ghz.jpg
4.2Ghz with water cooling:
http://img215.imageshack.us/img215/3...linxstable.jpg
Best I can get so far:
http://img188.imageshack.us/img188/7...linxstable.jpg
i7-920 - 3944a837
http://img256.imageshack.us/img256/1074/blendj.th.jpg
cooling cm haf922 & Titan FENRIR + 1x120 mm
Here's my new 920
Specs:
- CPU: Intel i7 920 @ 4.2GHz SLBEJ
- Memory: 6GB DDR3-1600 Corsair Dominator GT
- Motherboard: GIGABYTE GA-X58A-UD3R
- Graphics: HIS Radeon HD 5850 H585F1GDG
- Storage: 1TB WD, 1TB Seagate Raid 1
- PSU: PC Power & Cooling 750W
- Case: Coolermaster Cosmo S case w/black interior powdercoat
Cooling:
- (4) Scythe S-Flex SFF21E 120mm fans
- Swiftech MCP 355 pump
- Swiftech Apogee XT CPU waterblock
- Black Ice GTX 360 Radiator
- XSPC Acrylic Reservoir
- Tygon R-3603 1/2" ID 3/4" OD tubing
- NZXT Sentry 2 5.25" Fan Controller
http://img191.imageshack.us/img191/9...4200200wc3.png
Here's my i7 920
Intel i7 920 C0 @ 3.8
P6T DLX
6Gb Corsair Dominator 1600mhz C8
XFX GTX 295
Corsair HX1000
Seagate 7200.12 500Gb x 2 in Raid 0
WD 1TB Black series
ATCS 840
CPU & GPU EK Waterblocks
BlackIce radiators
This is what i got.
I did a run of 20 minutes on prime and on linX and it passed. I need to test lower vcore and qpi. I noticed that i only got the system stable giving the PLL 1.92v .
So basically i have:
19x200
Mems @ 8-8-8-24, 1604Mhz @ 1.64v
vCore @ 1.27200v
QPI @ 1.28250v
PLL @ 1.92v
Now i want to try if i can lower the qpi voltage... lets see.
http://img.photobucket.com/albums/v319/Postmodum/oc.jpg
And a snapshot ( badly taken ) of the system
http://img.photobucket.com/albums/v3...m/DSC02921.jpg
Intel 920 D0 3847A765
A small bench of my 920 D0 @ 4200 221X19 @ 1.28V
http://img510.imageshack.us/img510/4...417h43cpu4.png http://img689.imageshack.us/img689/4...17h43vcore.png
Also @ 4606 at 1.448V 1h30 OCCT
http://img716.imageshack.us/img716/3665/46061448v.png
@ Le Titi:
Really nice chip! :up:
Have you tried going further with HT off?
Batch is B: 3938B268
http://ense7en.com/pics/i7%20930/batch.jpg
Cooling = Corsair H50 w/ a couple Noctuas exhausting
http://ense7en.com/pics/Haf%20932/pu...%20exhaust.jpg
1.325v BIOS LLC level 1 = ~ 1.295v idle/load
4.3 GHz HT off
http://ense7en.com/pics/i7%20930/21x...-8-7-24-1N.JPG
Nice -n7- best 930 I've seen so far. Earliest batch I've seen too. Any results with HT on?
I simply can't push my chip any higher because of cooling limitations. I can't believe how hot they get even with water cooling below the 4.5GHz mark :eek: Fair enough I needed a TRUE for my Q9650 @ 4.3GHz but I virtually need the same standard of cooling for below 4GHz with my 920.
It's OEM - seems to be a batch no one else has as a result of this.
I cannot get temps down to decent levels w/ HT on sadly.
I was getting too hot @ lower vcore @ 4.15 GHz even, so i'm not going to worry about HT for now as i don't run anything that benefits from it.
It's true, the i7 runs way hotter than Core 2 Quad counter part especially when you have Turbo and HT on. When I had my MegaShadow I was only able to push to 4.0Ghz with 20 LinX pass but at 4.2Ghz after 5 pass it rocket through the roof with 85C and I couldn't run 20 pass without error. But after dipping it under water 4.5Ghz 20 passes and temp are still below the 85C, I know I can push more but I haven't quiet to play around with it yet. Get a WC setup for your i7 if you wanna push more. :up:
