AMD Athlon X2 EE + GBT 740G
Finally, after so much work, 18 hours non-stop, I managed to get my K10 HD working and restore all its contents! ;)
Just playing, check this:
The Athlon X2 4850e and 4450e [45W], both read whacko core temps, CPUZ does not really recognize them yet.
The GBT 740G also overvolts under load - 1.264v idle -> 1.296v/1.312v load
http://picsorban.com/upload/stock.thumb.png
CPU temp never moves
Core temp idles -1/-7°C at 25°C ambient with no TIM :rolleyes:
But BIOS does not read those temps, it reads far better
BIOS reads 31°C with core0 fully loaded
I tested till 93°C BIOS, k-type measuring TCASE was 8-12°C lower than BIOS temp, so that looks perfectly in-line
Anyway, EastyTune5 can access BIOS temps, so thats OK
Problem why I'm ticked is, I can't now run low HSF speed and HSF ramping on demand, since temp is always reading too high or too low in windows! :mad:
CnQ is 1G at 1.0v
Does not boot Geil or Crucial 1GB and 2GB 1066 RAM, only booted my Corsair 1GB 800 4-4-4-12
BIOS options are v.good for a £30 board, everything there I need
Boots Phenom 9850BE first BIOS
Stock idle system power draw with onboard is 48W AC -
Stock idle system power draw with onboard and CnQ is 40W AC - 75W AC load
Stock idle system power draw with HD2600XT is 74W AC - 102W AC load
Stock idle system power draw with HD2600XT and CnQ is 58W AC - 78W AC load
Next to try is K9A2 ->
