1 Attachment(s)
Just replaced 4200+ with opty 170
Hi guys. I decided to experiment with 170 overclocking. In a nut shell, replacing the 4200+ with an opty was a good decision. I'm already at a 600 mhz overclock at 1.47 volts. Much better than the x2. System specs are:
Asus a8n32-SLI
opty 170 w/Zalman 9500Cu
2gb Corsair xms4400
seasonic 600Watt SLI PSU
2x evga7900GTX's
SB X-fi
Adaptec usb2.0 Dual tv tuner
MCE2005
My current OC is 10x 260mhz FSB = 2600mhz @ 1.47volts.
This is the highest I've t tried so far. So far, so good. A half hour of dual, affinity set P95 and looping 3dmark06 tests good. Here is my compare URL for 3dMark06:
http://service.futuremark.com/compare?3dm06=335218
I Forgot to mention my stepping was BWE 0551, not a good week I think, but much better than the X2 4200, only hit 2.5 with that, same rig. I'll try higher and update as necessary.
