DFI powered
Powercolor X800XT PE Stock heatsink @ 605/605 = 33,453
DX8.1 with Omega 8.07
Win2K SP4 latest updates
Full system config in compre url description field :)
http://www.fileshosts.com/AMD/DFI/60...5_33453_tn.jpg
:cool:
DFI powered
:cool:
Nice overclock, though I feel you could higher in sandra mem.Quote:
Originally Posted by overcrash86
http://www.anti-x.org/bbs/attachment...f_a64_2600.gif
Man that's sick!!! :slobber: :toast:Quote:
Originally Posted by eva2000
Btw, is omega better than vanilla 8.07 in 3dm01?
i think omega 8.07 is slightly faster than ATI's 8.07beta
Btw have you tried the official 4.11? I feel it's faster than 3dm3 and 05 then the beta one. Not sure on 01 thoughQuote:
Too bad that 4.12 beta doesn't work on win2000...
cat 4.11 still slower than Omega 8.07 for me in 3d2k1 and 3d2k3 http://www.xtremesystems.org/forums/...ad.php?t=45705 haven't paid attention much to 3d2k05 though
you guys running old control panel style or newer ccc?
I'm 95% sure all DTRs are CGs. And as far as heatsinks go, just drill a couple big old holes in your mobo tray, and it won't matter how long the screws are, for the backplate. I've never used a retention bracket, I just mount my HS straight through to the backplate. :)Quote:
Originally Posted by ugp
old control panel .. since Omega 8.07 don't need CCC :)Quote:
Originally Posted by STEvil
thought I'd smash the 34k barrier :D
Powercolor X800XT PE stock heatsink @ 606/604 = 34,008
http://www.fileshosts.com/AMD/DFI/60...4_34008_tn.jpg
:D
Your 3700+ is a nice chip. What's the cooling and room temperature?Quote:
3DMark01 really love high FSB with tight memory timing!
Well there are some of them that are C0. Whether or not that is what I get I am not sure. Hopefully what ever I get is a good clocker and I can atleast get 2.4/2.5ish out of it. My heatsink should be here today :D My arm is going to be tired from lapping it I can tell you that.Quote:
Originally Posted by spaceman
But I will let everyone know the exact stepping codes on the CPU and what I can get out of it when I get it up and running and 'overclocked'
Well the XP-120 is alittle different than that isn't it?Quote:
cooling in sig, in compare url http://service.futuremark.com/compare?2k1=8245604 ;)Quote:
Originally Posted by ahfung
room temp 28-30C, water temp 28-31C :)
I've a friend who has bought a DFI UT250 and its priming at 370Mhz 100% stable with any mods :slobber: I couldn't pass from 310Mhz with my ex dfi...
It seems some are having all the fun with it and others are just stock at very small overclocks and then others are just having every problem in the world. It is very sad indeed. Not that DFI fault though I know. Just all the other hardware it seems to be.
OMG, now it's priming at 400HTT!!! :slobber:
I have all problems in the world also.
So your not alone =)
Will play with HTT a while, has nothing to do =)
I can't use more than 320 HTT at any divider. Just refuses to boot pass "Detecting array". Exactly the same with 272+ at 1:1. If clockgen didn't exist, i would have thrown this board aways a long time ago.
im testing my new cpu :D
http://mitglied.lycos.de/siedl/10x29...rtguardian.jpg
Ouch! What cooling?Quote:
Originally Posted by Mrki
vapo ls ...
i think i must have more than 30k with 2.9GHz or not?
thats a x800xtpe
http://mitglied.lycos.de/siedl/10x29...rk01_29951.jpg
Heck yeah, you should be scoring a LOT higher. Do you have your drivers tweaked up for gaming? That's the most common reason for bad scores, at least for me. ;)Quote:
Grab you some DNA-Drivers...I got my XP-120 today and I am going to wait to mount it until I get my 3400+ DTR. God I can't wait until I can do some more testing with it.
Why don´t you guys give me some real STABLE results with your "high" OC´s... ;) ... ;) ... :D
http://koti.welho.com/jlinna2/DFI%20...@1.81V_mod.JPG
though I don´t know if this is...
