any other suggestions for ram as i carnt get hold of the OCZ Flex II PC2-9200 4GB
what this gigabyte board like using all four ram slots thinking of getting 4x1gb sticks
seens these thats all http://www.envizage.com/p/737926/tea...2x1gb-kit.html
Brand new ud3p and EasyTune wont work for me.
It will start and it shows up in My task manager GUI; but it does not show up on the screen. BTW i'm running windows 7,,is it compatible?
This is one sweet motherboard. It has everything. Even com and lpt ports??
I have no use for them; but they are nice to have if i ever do need them.
I downloaded the latest eztune from Gigabyte, but it wont work either. Does the same. Running TeamGroup GMH and a q9650, looking forward to some krazy clocks.
Once i installed the new mobo, my vid changed in coretemp..now it reads 1.225?? Also when running stock the mobo defaults to 1.225V. In my old p35 mobo the vid was reported as
1.1000 and the mobo defaulted to 1.1000 ???
also my bios is f6
is that ok? or do i need to update.
Thats your real vid 1.225v.
BIOS F6 is good but F7 final is a bit better I think.
Regarding the ET6 I guess if you have a Windows installation that is not on drive C: it won't work.
I'm still testing this but you only see this when you try to open ET6:
http://i566.photobucket.com/albums/s...00992154PM.jpg
As soon as I discover what is really causing this bug I'll report back.
here is some decent priced rams. http://www.mwave.com/mwave/DeepSearc...8500&ALL=y&TP= I'm using now. Purchased in Jan. I paid over 10x as much for my first ones when they came out. The one I am using know seem ok. I have some 9600's I have not used on this board yet. They have been in P5K-e @600 for almost a year. I did use some G.Skill PQ's 2x2 in this at first and plan on putting them back in after a bit here.[IMG]http://img514.imageshack.us/img514/9711/4257yn6.jpg http://img514.imageshack.us/img514/4...pg/1/w1024.png[/IMG]BIOS F6 E8500 KHX 8500 2x1
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio...................: 0.0
CPU Frequency ............................: 4.257 (473 x 9.0)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control................: Enabled
CPU Host Frequency (Mhz) ...........: 473
PCI Express Frequency (Mhz) ........: Auto
C.I.A. 2...........................................: Disabled
Advanced Clock Control
CPU Clock Drive...........................: 700mv
PCI Express Clock Drive................: 700mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance......................: Turbo
MCH Frequency Latch....................: 333
System Memory Multiplier ..............: 2.40D
Memory Frequency (Mhz) ..............: 1135
DRAM Timing Selectable ...............: Manual
Standard Timing Control
CAS Latency Time.........................: 5
tRCD .............................................: 5
tRP............................................... ..: 5
tRAS.............................................. .: 15
Advanced Timing Control [Press enter]
tRRD.............................................. .: [Auto]
tWTR.............................................. : [Auto]
tWR............................................... .: [Auto]
tRFC.............................................. ..: 56
tRTP.............................................. ...: [Auto]
Command Rate (CMD) ....................: 0 [Auto]
Channel A
Channel A Timings Settings
Static tRead Value..............................: Auto
DDR Write Training............................Disable
REST AUTO
Channel B
Channel B Timings Settings
REST AUTO
Motherboard Voltage Control
Load-Line Calibration.........................: Enabled
CPU Vcore...............1.30000V..........: 1.29375v
CPU Termination.........1.200V............: 1.200v
CPU PLL.................1.500V...............: Auto
CPU Reference...........0.760V............: .760v
MCH/ICH
MCH Core................1.100V.............: 1.20v
MCH Reference...........0.760V..........: .760v
MCH/DRAM Reference......900........: Auto
ICH I/O.................1.500V...............: Auto
ICH Core................1.100V..............: Auto
DRAM
DRAM Voltage............1.800V..........: 2.140 v
DRAM Termination........0.900V.......: Auto
Channel A Address Vref..0.900V.......:Auto
Channel B Address Vref..0.900V.......:Auto
Advanced Settings
Limit CPUID Max. to 3...................: Disabled
No-Execute Memory Protect...........: Enabled
CPU Enhanced Halt (C1E)..............: Disabled
C2/C2E State Support....................: Disabled
x C4/C4E State Support.................: Disabled
CPU Thermal Monitor 2(TM..........: Enabled
CPU EIST Function.........................:Disabled
Virtualization Technology.................: Enabled
i installed 8 gigs of g.skill pc-8800's and using the same settings except for vdimm i was able to get this.http://i40.tinypic.com/33epzeq.jpg
This is what I've done so far, any suggestions? I had this same chip and RAM at 445x9 on my Abit IP35-E @ 1.42v. I got 25+ hours in Orthos at 400x9 @ 1.25v (1.3 bios).
http://i154.photobucket.com/albums/s...20x9Test14.jpg
E8400 SLAPL 420x9 @ 1.3v (1.375 bios)
Gigabye UD3P Rev 1.0 F7 Bios
Corsair Ballistix 2x1gb DDR2 PC8500
Seasonic M12 700W Modular
EVGA 8800GT
Antec 900
36x2gb Raptor RAID 0
@radaja: nice OC:up:,.. may i know what is that gskill 8800 rated speed, timming and voltage?
@turbotrey: if only u could lower that MCHcore a little bit, it shouldnt past 1.22v for 420fsb especialy with 2x1gb ram that underclocked :up: my guess is 1.2v already more than enough, but correct me if i'm wrong, im still noob :D
those crucial seems running with terrible timming, 5-5-5-15 would be great :up: and with PL9 for a start, pump that fsb!!!! :p:
thx
asap
EDIT: opss,.. fatguy replied just befor i edit :)
turbotrey
Ur PLL is too high, try 1.5v.
Also ur MCH is a bit high, 1.1v to 1.2v should be enough.
Also RAM timings, 5-5-5-15 should work.
Sorry to join in, but 8800 is rated at 1100MHz :p:
http://www.newegg.com/Product/Produc...82E16820231194
Those are really nice voltages, but try Prime/OCCT for >10 hours and IntelBurnTest >30 passes to see if it's really stable.
Why do you think F4 is the best? Does it allow lower voltages for the same OC or...?
I have an EP45-UD3 and e7300. It's nowhere near as good as all your e8x00 it seems. It needs 1.35v in BIOS for 3600 MHz, but anything above that requires a big voltage increase. 3.75 needs almost 1.42v and 4 GHz would probably take >1.475v. I've read it is not uncommon for e7x00 to require much higher voltages than e8x000, is it true?
In the end, I've settled for this. It's >12h OCCT Mix and 60 pass IntelBurnTest stable. Can you tell me if temps/volts are ok for 24/7?
IDLE:
http://img165.imageshack.us/img165/8571/0idlecp2.jpg
LOAD OCCT:
http://img165.imageshack.us/img165/5...oadocctmv4.jpg
LOAD IBT:
http://img165.imageshack.us/img165/8278/0loadibtli1.jpg
BTW How come Tcase is higher than core temps?
Hi Touche,
if there is new feature added in newer bios builds and i found it i'll consider changing the sysem bios then.
otherwise, i already have some of my favorite settings under the F4 version, and since i'm not looking for every bit of voltage or mhz i hate spending time on some more testing on the newer bios.
it's like it's been a while now that i use my boards, so it's not like i just got it yesterday or last week, so i'm kinda tired of redoing all the testing and things i already did.
I just wish they fix the S3 bug, it's pretty annoying. And a changelog for new BIOS versions would be nice.
hey touche, your MCHref is opposite to mine, i had to set it .72 to boot above 500fsb and VTT no less than 1.26 to get stable at 535, funny thing is i couldnt past 450fsb whatever voltage i set for MCH and VTT, but after update to F6, it perfectly stable for 535, tried 550 and 560 but no stability on windows, i guess my 8Gigs RAM limited my OC, will try to boot with two sticks next weekend and see if can get higher :) .. and thx for all the guys here with lots of info :up:
http://www.prototype.web.id/forum_images/xsmall.jpg
flo
Since ET vs BIOS MCHref is pretty confusing, what is yours set to in BIOS? At 400 MHz I've left MCHref at default 63% of VTT while increasing VTT to 1.3v. But at 500 MHz system would crash if I didn't lower the MCHref a step or two.
I've had trouble with F6. It wouldn't boot at PL10, only on auto (and maybe on manual but much higher than 10, can't remember). It seemed as if it always tried to boot at too low PL, even if it was set on 10. Went back to F5.Quote:
That's one nice e7300 you got there. Wish mine was as capable. Is it IntelBurnTest stable also?
Can your system wake up from S3 with current settings?
i had similar confusion regarding this bios and ET but i read a post several pages earlier that if you want to use 1.3VTT u have to set it at default first that is 1.2 then u can adjust cpu and mch ref according to your need then set the VTT back to 1.3, youll get correct value on ET, thx to that who posted it :up:
Whenever i set PL9 it wont boot, whichever bios version i use :shrug: so PL10 that is
i used burntest but my temps goes up to 80c :eek: so i just use orthos blend to check if its stable enough :p:, VID is 1.1250
yeah i have similar issue with this S3 but i think its common i have no idea wether they fixed already with latest bios
asap
I guess you have 0.9v MCHref then. I've mostly seen people having to raise their MCHref, so I was quite surprised to see that I actually have to lower it. I wonder why that is?
I have another small problem besides the S3 bug. My Steelseries Ikari Laser sometimes doesn't work after waking up from S1. I have to unplug it and then plug it back. Haven't tried other mice though, nor this one in another computer.
