why is your TRRD setting loose?
you should be able to do 1200cl5 @ 1.9Xv with trrd 5 mate
Cuz I get best performance & stability at 5-8-5 (trrd/trd-wr/trtp), I've run the everest benchmark like 20 - 30 times switching between 3-8-3 for example but I get same or slightly better performance at 5-8-5. ;)
I've spent lots of time getting those scores I'm getting at those configs that I can assure you of, I've tried all timings one by one to find the best settings.
trfc I could prolly lower still to like 22-23 but 25 is such a good number already at these speeds it satisfies me like this. Also tref could possibly also use 4041T setting but yea I'm fine like this really for 24/7. :p
I doubt it's easy to get better results than that at 4.0GHz, especially the DDR2-1000 config and with less than 2.15v for the RAM. 1) It needs a P35 board (for PL7 at 500 fsb) and 2) Good D9GKX or some of the best D9GMH sticks.
There are prolly some more efficient boards out there than my P35 DS4 tho, especially the latency at DDR2-1200 5-5-4-10 is rather high at 50.9ns (I'd expect some boards to do around 49ns at same settings) but DDR2-1000 4-4-4-8 48.9ns then again is acceptable thx to PL7.
sorry, your sig said :
did you mean you can run 4 stick of ram @ 1200 with the dfi-x38 ?Quote:
Originally Posted by zsamz_
i'm trying to find the right mobo for 4x1gb overclocking.. my current dfi dk p45 don't do well with 4 sticks of team xtreem pc8500.
thx :)
edit : woopss.. it took me more than a year to post my first post here @ xs :D
:yepp::yepp: dfi x38-48 can do 4 stix 1200mhz easy
the ut p35 can do 4 stix around 1150mhz
dfi dk p45 cant run 4 stix properly need proper bios
i maxed out 4 stix on x38@ 1274mhz http://www.xtremesystems.org/forums/...d.php?t=226666
Hy all
Small fun in day :)
http://img507.imageshack.us/i/1001449e.jpg/
http://img170.imageshack.us/i/1001467.jpg/
1560 Mhz CL5 http://valid.canardpc.com/show_oc.php?id=592765
Crucial Ballistix Tracer
EP45-UD3R
toyone
Wow, thats extreme! Great job really :up:
Thanks WaterFlex
Hungarian record 1580Mhz CL5
Did not manage to disprove it for me. Maybe later ;)
TOYONE,holy cow that is awesome
:bows:
Just got another set of D9GKX in :rofl:
http://img193.imageshack.us/img193/3535/dsc00314pri.jpg
got my first sub 10 32m score:D
http://i42.tinypic.com/ok0sgn.jpg
everest score at 9x545@4905 ddr1308 pl8
http://i42.tinypic.com/5tvs0l.jpg
Shiranui Gen-An looking forward to your results
with these stix
I examined the chips from the sides. No feet like Elpida, flat just like the rest of my D9 sets.
Ballistix 16FD3:
http://img10.imageshack.us/img10/428...0336zzv.th.jpg
HyperX:
http://img4.imageshack.us/img4/7017/hyperxics.th.jpg
I think this is the most convincing evidence :D
http://img33.imageshack.us/img33/286...yperx1m.th.jpg
*EDIT* Ignore the SmartGuardian VDIMM reading, it is set to 2.45V in the BIOS.
radaja congratulations sub 10 min 32M :clap:
thanks toyone.going to try for 9x556@5004
not sure if i can do it on air though,but going
to try it an do a quick 1m run.
good luck:up:
well this is as high as ill go for now.
9x549@4941 ddr1317 pl8 1m Pi
http://i40.tinypic.com/2qalaab.jpg
9x549@4941 ddr1317 pl8 32m Pi
http://i43.tinypic.com/eio49d.jpg
and the everest score
http://i41.tinypic.com/hv12f8.jpg
:clap::up:
today is a good day to finally hit5Ghz:D:D:D
9x556@5004 ddr1334 pl8
http://i42.tinypic.com/14aext.jpg
everest score(this is on 32bit OS)
http://i40.tinypic.com/2zdytd1.jpg
Gratz radaja, what cooling did you use?
