DFI AGP has more issues than the MSI. I was thinking about it to but i havnt seen any people who are able to get better overclocks with the dfi when they traded from the MSI.
We Can now add any memory timings we want to the bios by editing the bios so it doesnt matter if MSI add any more or not really. Voltages well the new venice san diegos dont like high voltage anyway and same with modern ram and a ddr booster works as well and is cheap.
The MSI is a very stable board im sure there are bad versions of it but i have a good one and its highly stable, voltages hardly fluctuate and the cpu clock is also highly stable you set 250fsb u get it dead on.
Raptors die all the time btw i doupt it was the motherboard to blame.
BTW NFM cd1986 made a 1.96 beta bios that removes the cpu temp reading and so will load setup. I had the same issue as you did and the bios works now that setting was removed.
no temp bios
