Originally Posted by ugp
im now at working!
sure is this 1T :D ... i never take 2T!
i post a sisoft screen at the evening ;) ...
yes this is amazing 2x512 ddr600 @ 2.5-3-3-7!
p.s my vapo ls i arrived today! i will not sleep the next 3 days :D
im now at working!
Weird. The 9x multiplier works with my OCZ3700EB but not my PQI Turbo TCCD.
Just got back my UT from RMA.
Looking for memtest screenie @ best settings for ADATA PC4000 or TCCD w/ 9-10x * 250 FSB 1:1. List CPU and stepping (ie. CAAPC, CBASC) for both CH and NC type chips?
I dumped a 3000+ CBASC NC into my VNF-250 @ 9-10x *250 1:1 w/ both of the above and got 1993 and 1997 mb/sec stable respectively.
Do same thing w/ UT and get ~1662 MB/sec iirc.
That seems to be bad. :confused: :shrug: :wierd:
If you get close to where I am w/ the VNF, please include tweaker screenie :D
So until someone can validate or explain why I get such a discrepancy I am playing w/ DC.
Not to shabby. DFI UT, PC 3700 Platinum TCCD Brainpower 808 at 3.2 vdimm. Prime stable for 3 hours (i stopped it)
Well I ordered a XP-120 with a 120mm Blue UV Fan. It pushes about 70+ CFM. It should be decent enough and I also got an extra 120mm of the same to mount over my RAM. I bought me some 800-Grit, 1,000-Grit, 1,500-Grit, and 2,000-Grit sandpaper to lap it down real good. I am going to see if this helps out any. If either case I plan to buy a 3400+ NewCastle DTR from NewEgg. Hopefully after I get that I will be able to push my system alittle further. I am hoping anyway.
EDIT: All I can find now is ClawHammer C0 stepping CPUs for DTRs. Is that all there is anymore? Or is another ClawHammer C0 worth trying?
Link to DTR Here...
dont use nvidia IDE drivers and dont use the network manager. me installed windows yet again today.
now trying 304x8 with ram at 270 (9/10 div) will try 315x8 maybe with ram at 280
with vmod to +3.3 my PC2700 like :D
http://perso.wanadoo.fr/overcrash86/...270superpi.jpg
http://perso.wanadoo.fr/overcrash86/...PC2700@288.jpg
but my ADATA have a problems with the voltage over 3v ,i'v tryed with 3.1v (unstable):
http://perso.wanadoo.fr/overcrash86/...@310sisoft.jpg
Got my a64 3400+ mobile 62W today :D
This is what i have testet so far on air with SLK948U and Papst92mm
http://img.photobucket.com/albums/v231/Fosco/jessda.jpg
What memory do you use ?Quote:
Originally Posted by Fosco
OCZ EB :confused:
Fosco,
Was that from itbutikken? What stepping did you get?
It`s frome shg.dkQuote:
Originally Posted by mackanz
Stepping: CAAXC 0430VPMW batch 0038
overcrash86: it is ocz 3500eb 512mb
with my OCZ EL PC3500 ,i go only to 260 ,but with more woltage :
http://perso.wanadoo.fr/overcrash86/...0+/OCZ@260.jpg
how can i get more oc out of my cpu? those with cpus around 2.5ghz+ what drive strength are you running? ive tried loosening almost every ram timing and can only get 304x8 not stable with ram at 270. now im setting for 320x7 ram at 280
but ram clock doesnt increase my 3d perfomce and i only get max 37s superpi no only 40s :(
Mrkl,Quote:
Originally Posted by Mrki
Damn nice Ram & chip you got there :toast:
Well the important thing to consider is, the higher the rating, the more multi options ya get. OT, but can someone explain how ya take a screenie of Memtest 86? Thanx. :)Quote:
Ok..then what I plan to do is get a 3400+ DTR. Where can I get some good ones from cheap?
Do they ship international?Quote:
I am on the hunt for one of those now. I want one!!
AMA3400BEX5AR
If anyone finds one let me know! LoL
That is for a Clawhammer. The 3400+ Newcastle will run 2.4 gHz stock AND give you the 11 multiplier possibility ( may be more friendly to a wider array of RAM ). I thought about going that route, ( my 3400 AR Clawhammer is decent at roughly 2.5 gHz ) but fiured if I'm going to get another A64, I might as well go DC/939. Also, aren't the 0432 stepping ( or later ), the 3400+(s) that are showing such overclockability?Quote:
I am not sure. I just want to get another A64 that will overclock well and then put my old MSI A64 system back together with my 1GB of RAM and 9700 Pro that I have. And then my girlfriend can have a little gaming machine of her own :D Maybe I can get her into Day of Defeat and Counter-Strike :DQuote:
Originally Posted by serlv
I think I am going to get the 3400+ DTR from NewEgg. It is a ClawHammer and it says it is a C0 Stepping. I would love to have a NewCastle 62w CG Stepping. But I am sure the shipping on one from Overseas is unreal.
EDIT:
Also, I notice the all the pictures of the DTRs the IHS is already removed. If they come like this as so...would I have the mod my XP-120 and retention bracket in anyway to have it make good contact with it? It was just something I remember wondering.
>>>>>>>>>>>>>>>>>>>>>.Quote:
the xp-120 works just fine with a nude CPU.
baldy :D
HEHE! I am thinking of stripping my 3200+ nude :D
Not sure if I know how to do it right and am afraid of ruining it.
Hopefully my XP-120 will be here tomorrow and I can begin the lapping process. I am going to use it to shave in after I am done lapping it lol.
EDIT:
Well I finally gave in and ordered the 3400+ DTR. Newegg Says it is a ClawHammer but hopefully it is a later one and does alot better for Overclocking. Atleast I have the benefit of the 11x multi to play with.
Well, let us know the week and stepping, when you get it. Thanks.
Nice score, here's my 3200+ @2.65 score, with memory at 265MHz 2.5-3-3, which is the highest a Hynix D43 can do.Quote:
http://www.hkepc.com/bbs/attachments..._cupmark99.jpg
It's funny to see that after 2.6GHz for every 10MHz it scores 1 more point in CPUmark99.
I did that to my 3200+ from day one, so I can't tell how much it help in overclocing. But it did drop the temp quite significantly.
