any updates on the 512 oc bios?
Originally Posted by HeavyH20Hey guys. Haven't visited for a bit. Been running through the paces on the BFG 512's I have.
Some initial findings:
Default mem timings are in slot 3. The interesting thing is the timings are already tightened a tad from 1.1 ns GDDR3 spec. That is probably why the cards are rated to 1700 instead of the 1800 you would expect. Second, no delta on the new core, which is interesting in light of the faster DDR. You would think that the vertex cores would have even more work to keep up with fill from the DDR. Anyway, trying some BIOS mods to increase memory speed and also playing around with delta settings.
Back to the prior posts, I will be releasing a 20 MHz delta BIOS for the GT. My findings have shown this to be optimal on the GT cards. I will post that in a bit. Still doing a little assembly work on a couple of PC's.
The memory timing tweaks I adjusted do not affect memory OC. The best thing to help is heatsinks on the backside and a low speed 80 mm fan mounted on the side of the card. Keeps the memory a little cooler and the VR reg heatsink from getting too hot.
I should have a good OC BIOS for the 512 by Sunday evening. I will post some comparison numbers of before and after.
Hope these small changes see some even higher scores!
