I'll take you up on that offer...
I am bidding on one as we speak. How is it? I am leery of the 12ms response time. Does it perform well watching DVDs? Gaming?
I am trying to get one for around $750, how much did you guve for yours, and from where?
Thanks in advance for your thoughts!
F6
Don't buy VP191B for games
I just wanted to add my own experiences with these monitors. I have used both an L90D+ and a VP191B which I purchased recently. I compared the two at the same time by connecting them to both of my graphics card and running them in clone mode. I am actually writing this review using the VP191B right now.
Unfortunately, while not being a bad monitor, In my opinion the VP191B is very overrated. The reviews at sites such as Tom's Hardware Guide would lead you to believe it performs better than TN panels. This is simply not true. The color accuracy is certainly better using the VP191B, and you can enable font smoothing without the text becoming tinged greenish or reddish (a problem you will run into on a TN monitor like the L90D+).
The problem is in games using the VP191B there is very visible ghosting. It is quite noticeable and very distracting. The ghosting is apparent during transitions between darker colors (dark gray or black) and lighter areas. I tested out a few games and you can see it in Guild Wars, and it is just terrible in Doom 3 (the game is very "busy" with a lot of lines on the walls and all of them blur/ghost when moving). I think you could play games on this monitor, but I would not recommend it unless you are not very sensitive visually (if you're the type that can't tell the difference between a CRT running at 60Hz and 100 Hz then maybe you won't notice). Other than that I think you will be very disappointed in games.
With the L90D+ the ghosting is much less bad. It may exist, but I really can't even see it. The color accuracy is not as good so font smoothing is unusable, but other than that the color is fine. In fact, the colors are actually more vibrant and the dark level is lower than on the VP191B. Movies look fine on the L90D+, and they also look fine on the VP191B, although the lower brightness level of the L90D+ is a small bonus.
Overall I would strongly recommend against buying the VP191B, not just because of its performance in games, but also because it is so much more expensive than the L90D+ and other comparable panels like the BenQ FP91G+ or VX924. If the price were equal then you could weigh the trade offs between the VP191B and a different panel, but considering the price is $100-$150 higher, the VP191B is simply not worth it, especially if games are important to you. The L90D+ on the other hand is an awesome panel, with the exception of a little loss in color accuracy, it performs very well in games and looks damn good too.
Also, while games play decently on the L90D+ which I believe is rated 8ms (although the ratings are kind of inaccurate in themselves), I would not consider anything slower for games. I really feel that a 12ms monitor will probably perform very poorly based on my experience with the VP191B. Anything much slower than the L90D+ may suffer from some pretty bad ghosting.
