Originally Posted by zakelwe
I've got the 754 board but have similar power issues
1) Machine boots up just flicking the power switch on the wall without the proper switch from the motherboard
2) False start 1 as mentioned in the thread... machine spins up the fans for 1 or 2 seconds and then dies
3) False start 2 as mentioned in the thread .. machine spins up fans but no screen image.
I had an MSI board as a replacement, my first one worked fine. The replacement did the above. I sent it back and got another, the replacement did the same. I left it in disgust and a few days later gave it one last time and it worked fine. It now works fine all the time as well, but i have had some troubles before this last good spell.
Having read the thread I notice a lot of GF 6800 cards being used. Interestingly, looking back at it, when my replacement board arrived I was using the 6800, but when I gave up with it I put the 6800 in my P4 and used it there. When it booted up after a few days it probably had my Fx 5800 in there. Now i have tested it since with the 6800 but I have had some troubles, at present the FX 5800 is in there and it seems OK
To be honest I cannot quite definitely match up when the 6800 was in there and when it was not and when it had these strange boot problems.
The only thing I can do is try 10 boots tonight with FX 5800 and then 10 with the 6800 and see if stability goes.
Can someone else with the problem and different video cards do likewise ? This will show if this theory is a false start ( cough, pardon the pun :) )
Regards
Andy
