what is NB Speed that does not show up in CPUZ ?
Here's where i'm at so far as far as one game in particular, NB was stock for this test on BD.
Both systems are 4 core 4 thread, i find anything more than 4 pointless for gaming 90% of the time.
http://www.xtremesystems.org/forums/...5&d=1318888545
http://www.xtremesystems.org/forums/...8&d=1318888798
Anyone know about K15 stats?
Bios 9913
Catalyst 11.9 kept givin' problem for crossfire setup
http://img836.imageshack.us/img836/4...nshot018zd.jpg
That's on ambient, right?
If I knew I could get a CPU like that I won't mind buying BD. It seems like power consumption will go through the roof at those speeds/volts though.
Considering everyone has been using 2v+ on these CPUs with LN2, I'd be inclined to think that these CPU's are more voltage tolerant than Thuban/Deneb but leak more...correct?
With my 3x120mm radiator and AP-15's I doubt I'd need to worry about a temp wall.
He's on phase...... you might be able to suicide that on 1 core ambient ..........
think, Daveburt has great FX...over 5100 MHz Cinebench with 1.4V looks awesome. Maybe he has gold one :)
Using DOCP and ram profile 0 which is xmp 2133 C8
http://img408.imageshack.us/img408/9...nshot067ll.jpg
2133 is no problem....I had 2200 8-9-7 stable. Keep pushing! Ah srry, DOPC profile...
Nice IMC you have there Dumo, what Vtt is that at?
My 8150/CHVF combo came in yesterday afternoon. :up:
It seems my chip has a default/PS0 (3600MHz) VID of 1.287. Ran a first o.c test with 1.35v @ 50% LLC cooled on air with TR Archon (push/pull). I usually run a daily "crunching" o.c. with my 2600K at 4.6 GHz (HT) ~1.3v (load) but with BD's higher TDP it may be hard to keep the temps manageable at 4.6+ eight core (load) on air.
http://i695.photobucket.com/albums/v...-815044Ghz.png
DUMO: nothink, I dont seen first time you are talking about DOCP profile for RAMs...And I thought, u show only max memory clocks :-)...
Nice PR:up:
You'll have a lot of fun oc'ing this one. The Coolest working on Coretemp that can read BD's tdp/power draw
Thats ok Flanker:) DOCP and C6 enabled seem to help with stability and heat load in windows
Winrar...
http://img831.imageshack.us/img831/9...nshot020pi.jpg
I read that as
"2133 is no problem, (I didn't bother too look at your screenshot)....I had 2200 8-9-7 stable. Look at me. You, however...keep pushing! Oh wait, you can't (even though you can...), DOCP profile...
I need DOCP to clock ram at all on CHV (with Thuban)...however with DOCP, 2050 6-9-6 was doable in 32M at 1.75v (6-10-6 isn't totally stable in itself...prime fails :/ )
Hopefully FX soon enough, just to try something new. Not impressed at all by performance.
Yeah, I will be limited to dice for a while and from what I've seen 8150 is the way to go cold...no money for that.
LN2 price is through the roof so I will have to work with DICE again :/
The problem with BD for me is the performance:power ratio, (+ ST perf) its too inefficient. It almost seems that GloFo's 32nm is worse than their mature 45nm.
Mind if I post any Thuban results? I've got nothing else to do but run wPrime 32M, pifast, Cinebench 10 / 11.5, SuperPi 1M+32M etc.
EDIT:
(Sorry for littering with more BD 'hate' :p:)
No problem Beep
Well I've been testing my 8150 some more today and it seems that it may have one weak module/cores?
I'm not having much luck when I attempt to stress with Prime it usually/mostly fails (sum out error) in thread 7 but sometimes thread 8 will fail instead. I'm not sure if there is some voltage or setting I'm skimping on but I'll keep working it. I may have to bin another chip if they ever get some in stock at my local Micro Center. My combo so far has rarely blue screened and the few times it happend was while trying to load into windows at 5.2GHz with not enough vcore and too much vdroop. http://valid.canardpc.com/show_oc.php?id=2056223
