Originally Posted by
massman
What are those performance charts based on? DX9, DX10, DX11 or a combination of all?
You're undermining your own argument by using either too little or too much data to prove that 3DMark Vantage, an indication tool for DX10 performance, is inherenlty producing false results. If you want to compare DX10 performance accuracy, you need multiple (more than two) DX10 benchmarks using the same resolution as the preset you're comparing your results to. Preferably also the same IQ settings. You have to exclude all data that does not fit the comparison, which includes alternative resolutions, IQ settings and game-types.
Then, to prove 3DMark is inherently incorrect, you will need to do correlative research to find out if one of your OWN games is biased specificly towards one type of graphics card as it might bias your overall figures.
If you've done all that research and still come to the conclusion that 3DMark is wrong 50% of the time, you can write an article which will end with the conclusion: "although 3DMark gives you a good view on what hardware is capable, when considering purchasing a new graphics card it's better to check out more than just the 3DMark number". Also, you might want to give readers the advise to also check out other hardware websites to see if different platforms give different performance.
So, the conclusion of all this: if you rely on one graph to decide what product is best for you, you're a retard.
